I dont know how to fix this - Chevy Impala Forums
 4Likes
  • 1 Post By plano-doug
  • 3 Post By Bill58
post #1 of (permalink) Old 04-09-2019 Thread Starter
Rhouston713's Avatar
Whats up guys, my car started overheating so i had a mechanic look at it. Apparently the heater hose was broken and it was leaking. As he was replacing the heater hose he noticed the new one just wouldn’t fit in the hole so i did a little more looking around and i found out what the issue is. I do have the correct piece but the old heater hose melted off inside the hole so the new one won’t fit inside. I will post pics so u guys can see what im talking about. The first pic is the old hose, the second pic is the new hose. That little piece that you see in the new hose broke off from the old hose and its stuck here, in the third pic you will see. It is like so stuck and it melted in the hole, i can’t fit the new hose inside.
ID:	145273   Click image for larger version
ID:	145275   Click image for larger version
Rhouston713 is offline
post #2 of (permalink) Old 04-09-2019
Quoted: 329 Post(s)
Originally Posted by Rhouston713 View Post
It is like so stuck and it melted in the hole, i canít fit the new hose inside.
You need to dig the old piece out. But DO NOT SCRATCH the inside of the opening. The o-ring seals against that surface, and if you gouge it, you could end up with a hard-to-fix coolant leak.
If you compare the new pipe and the old, you can see you have a short length of pipe stuck in the hole. You want to insert something into the hole and hook the bottom edge, or insert two on opposite sides for a better grip, then slowly pull the old section out. The key is that the pieces you use to hook it must have very short hooks - just enough to hook the bottom lip without sticking out radially far enough to scratch the inside of the pipe.
In short, you might need to fiddle around some in the shop using a vise and a bench grinder to fashion some sort of tool to do this.
Or go to an auto parts or tool store and look around to see if they have something that might do the job without hacking it to fit.
Another thought is a large diameter screw that you put in the hole and turn it until it is snug, then wiggle it while pulling to extract the piece of pipe.
In summary, I'm pretty sure you can get that thing out, but be careful to avoid scratching the inside mating surface.
12 lt likes this.
post #3 of (permalink) Old 04-09-2019
Bill58's Avatar
Quoted: 44 Post(s)
Get a tap and cut threads inside the stuck piece. Thread a bolt in the stuck piece, attach a slide-hammer. Gently slide-hammer the stuck piece out. You can remove any metal shavings/chips with a magnet. I'm sure many ways but that was my first thought.
plano-doug, 12 lt and kbz1960 like this.
Bill58 is online now
post #4 of (permalink) Old 04-11-2019
gahsr's Avatar
If you can get an easy out it would safer than trying to pry it out.
gahsr is offline
Seat back fix John Craker Chevy Impala 8th Gen Discussion 1 04-10-2019 05:36 AM
Lucas Transmission Fix? Dave_N 8th Gen Drivetrain 7 04-04-2018 04:56 PM
'08 3.9L transmission fix with only solenoids imduffer1960 8th Gen Drivetrain 4 03-05-2018 12:31 PM
'08 3.9L Transmission slip fix replacing only solenoids imduffer1960 Chevy Impala 8th Gen Discussion 5 01-31-2018 10:46 AM
Impala Dash Tapping Fix. carnau Chevy Impala 8th Gen Discussion 34 12-01-2017 08:23 AM
