2003 Impala High Beam Out - Chevy Impala Forums
post #1 of (permalink) Old 09-30-2019 Thread Starter
Hgreen's Avatar
I am having an issue with my turn signals, they work but are dim. My message center says High Beam Out but my lights are working. Help!
Hgreen is offline
post #2 of (permalink) Old 09-30-2019
Quoted: 218 Post(s)
Dim bulb performance usually indicates a bad ground, or a corroded socket.
Remove the turn signal bulbs and examine the inside of the sockets. If not too corroded, you can clean them with electrical contacts cleaner (and clean the base of the bulbs). Reinstall with a small amount of dielectric grease (available for about $1 in many auto parts’ stores in “ketchup pack” style packs).
Following the wiring harness that from the headlamp capsule. Usually the left and right are separate, and plug into a front, cross car wiring harness. Remove the electrical connectors and examine them - clean as above. You may have remove some items, or follow the wiring harness path with a mirror.
Remove the high beam bulb and examine the socket. Clean as above.
1999 White C5 Coupe is online now
post #3 of (permalink) Old 10-05-2019
wz7u's Avatar
Quoted: 5 Post(s)
Have you installed aftermarket LED headlight bulbs by chance?
I did and am having the High Beam Out issue as well. I'm told I need to buy some sort of intermediary box to cure the problem. I'm considering simply converting back to standard bulbs to alleviate the problem.
'03 3.4 with lots of miles, 230k+
wz7u is offline
