P1032 Code- bnk1 Snsr1 Upstream OS? - Chevy Impala Forums
  • 1 Post By Bart77
post #1 of (permalink) Old 09-13-2019 Thread Starter
markielmusic@gmail.com's Avatar
Post P1032 Code- bnk1 Snsr1 Upstream OS?
Hello everyone, I was hoping to get some advise as I am getting an error code P0132 which looks to be the 02 oxygen sensor bank 1 sensor 1 Also with some idling and engine light.
This looks to be the "upstream" sensor that many say is pretty straight forward to replace. Its looks to be in the front lower part of the engine.
I was looking on the site to see if there were any post I could reference to make this repair as smooth as possible.
thanks for any insite.
2015 chevy impala LTZ 6 cylinder
post #2 of (permalink) Old 09-13-2019
cj1
cj1's Avatar
Quoted: 14 Post(s)
Sensor is reading a rich condition 1v can you introduce a vacuum leak to see if it will drop down to .2v?
Reason being it may not be the sensor at fault could be engine running rich.
Fuel trims are normal LT+ ST within plus/minus 10?
In addition circuit signal/heater circuit could be at fault.
Pigtail connection tight?
May disconnect/reconnect to see if have any effect.
cj1 is offline
post #3 of (permalink) Old 09-16-2019 Thread Starter
Thanks for the response, I ve heard this term before running rich but not 1 v. can you elaborate when you have a moment.
post #4 of (permalink) Old 09-16-2019 Thread Starter
Update, I replaced the upstream sensor and reset the check engine light but it still came back on. Checking to see if I get the same error code. Will update once I have it checked.
thanks for the input.
post #5 of (permalink) Old 09-16-2019
Bart77's Avatar
Quoted: 37 Post(s)
I believe both upstream oxygen sensors are the same, I'm saying this just in case you replaced the wrong one and you could install the sensor you removed into the other location if this is the case. The firewall side of the engine is Bank 1 and the radiator side is Bank 2.
Bart77 is offline
