Floor Jack locations - Chevy Impala Forums
post #1 of (permalink) Old 07-05-2019 Thread Starter
tired08's Avatar
I have an 08 impala. I used the crossmember to jack the car up. The lip of the crossmember in that area bent slightly. Would using a piece of wood prevent it from bending more next time or is the a different spot I should use?
tired08 is offline
post #2 of (permalink) Old 07-05-2019
Quoted: 232 Post(s)
Usually use a 2x6 about 16 inches long on my wide body floor jack here. No issues with it bending anything that way as it distributes the lift point more evenly.
post #3 of (permalink) Old 07-05-2019
kbz1960's Avatar
Quoted: 22 Post(s)
Hum. I just use the same location for the regular jack.
kbz1960 is offline
post #4 of (permalink) Old 07-08-2019
Quoted: 253 Post(s)
i would use the rear motor mounts of the engine cradle in the front (the cup of the jack fit nicely around the bushing location to cup it well) and in the rear beefy looking center section of the axle i think it was in the rear. in the rear i would use a board to help if i had one nearby. on the rear axle i will note you wanted to make sure you didn't get any of the tie rods or other smaller bars running through that area as it could bend them with the weight of the car.
Joes74challenger is offline
« P0336 | Misfire »
