1999 Chevy Suburban 1500 LT - Chevy Impala Forums
 10Likes
  • 3 Post By plano-doug
  • 1 Post By 12 lt
  • 3 Post By 12 lt
  • 1 Post By Old Bones
  • 2 Post By 12 lt
NickDalton's Avatar
Quoted: 53 Post(s)
My mom has a 99 Suburban and she keeps having to get her flywheel and starter replaces about once a month. She notices itís starting to go out when her engine doesnít start it makes a whirring sound and then not too much time after that her starter goes out. Iím assuming the whirring is the flywheel messing up, which then kills the starter. But the starter and flywheel doesnít just go out for no reason. There has to be an underlying reason as to why they keep going out. Now, I live 600 miles away, so I wonít be able to try the things you guys say, but I can relay them to her. Iím trying to give you as much information as possible to help answer it, without you guys waiting on me to get back in touch with her to get the answers you guys are seeking to diagnose the problem.
My first car!
P.S I fixed it haha.
NickDalton is offline
04Imp38's Avatar
Quoted: 235 Post(s)
Do they replace the flywheel every time? Iíve never heard of that.
Maybe they are replacing the starter instead of the flywheel and the flywheel is bad so itís taking out the starter gears.
~Joe~
04 Impala LS
Engine: ZZP PCM, ZZP Downpipe, Xcelerator Resonator, Dual Xcelerator Mufflers, 4" Stainless tips, 180į t-stat, Shorter Dogbones, Mount Spacers, Optima Red Top Battery
Interior:
04Imp38 is offline
NickDalton's Avatar
Quoted: 53 Post(s)
According to her they replace the starter and the flywheel every time.
My first car!
Quoted: 307 Post(s)
I'm thinking you should call the repair shop and speak directly with them. They need to explain why they think the flywheels keep failing. Are the starters chewing up the flywheels? Are the starters properly aligned/shimmed?
Maybe your mom can scan and email you the receipts so you can see what was written in the paperwork.
The shop needs to explain what they were diagnosing each time and why the first fix(es) didn't work.
Old Bones, 12 lt and kbz1960 like this.
Quoted: 210 Post(s)
Agree with Doug. Get her to send you a detail of what the shop is doing and call and talk with them yourself. If they replaced the flywheel once and put in a new starter that should have solved ANY issues unless the work they did was no good or used used worn parts and/or they did not get the starter properly aligned which would be the shop's fault and they should repair free of charge if that were the case.
Hate to make assumptions or be ugly, but if what you say is accurate the shop may be taking advantage of your mother because they know she does not know anything about mechanics.
kbz1960 likes this.
post #6 of (permalink) Old 2 Weeks Ago Thread Starter
NickDalton's Avatar
Quoted: 53 Post(s)
Oh I probably shouldíve mentioned that itís not a shop, my dad and his brother have been replacing the starter and flywheel. According to them thereís nothing wrong, she just needs to keep replacing the starter and flywheel. Her car broke down last night and started smoking she had to get it towed home.
My first car!
Quoted: 210 Post(s)
Sorry, but have to ask are your mother and father married and on good terms? Makes no sense to have to change something if nothing is wrong.
plano-doug, gahsr and kbz1960 like this.
post #8 of (permalink) Old 2 Weeks Ago
Caprice Classic with Class
Old Bones's Avatar
Quoted: 66 Post(s)
Just a thought , has the vehicle ever been in an accident that could have bent things out of alignment ?
Holly 0-83670 4 Barrel Carb. Headman Headers. Magnaflow Cats. Flowmaster Delta 50 Mufflers.
Electric Fan. Compu Star Alarm. Sony F-50 dash-cam with GPS Antenna. Crazy Canuck behind the Wheel.
Old Bones is offline
post #9 of (permalink) Old 2 Weeks Ago Thread Starter
NickDalton's Avatar
Quoted: 53 Post(s)
Ehh they are separated, and on decent terms. I mean I know he wouldnít sabotage her vehicle intentionally.
My first car!
post #10 of (permalink) Old 2 Weeks Ago Thread Starter
NickDalton's Avatar
Quoted: 53 Post(s)
Someone did hit her front end and it dented the bumper. Iíll have to see if I can get a picture.
My first car!
post #11 of (permalink) Old 2 Weeks Ago Thread Starter
NickDalton's Avatar
Quoted: 53 Post(s)
Sorry for the late replies guys. Been working a lot.
My first car!
post #12 of (permalink) Old 2 Weeks Ago
Quoted: 210 Post(s)
Ehh they are separated, and on decent terms. I mean I know he wouldn’t sabotage her vehicle intentionally.
If there is still a problem with the starting system, your mom might want to get another opinion from a shop or reputable mechanic next time it messes up. No reason after the first time the flywheel and starter were changed that they should continue to need to be replaced. Especially not on a monthly basis.
Not saying your dad is screwing her over, but something there does not seem quite right.
The Following User Says Thank You to 12 lt For This Useful Post:
NickDalton (21 Hours Ago)
post #13 of (permalink) Old 2 Weeks Ago
brainstorm's Avatar
I am sorry, but tell me please, what car for the first time would you recommend ?
Let's assume, that I have 3-4 thousand $
brainstorm is offline
Problem wiring up aftermarket amplifiers to my 2016 chevy impala lt Chevyboy8890 Audio, Video, and Electronics 8 09-07-2018 04:58 PM
2016 chevy impala LT limited Rashid63 Appearance 8 10-23-2017 08:46 AM
New original OEM Chevy Suburban Avalanche transponder chip key 07 08 09 10 11 12 RSS Bot Impala Diecast Toys Cars on eBay 0 08-26-2017 02:50 PM
New original OEM Chevy Suburban Avalanche transponder chip key 07 08 09 10 11 12 RSS Bot Impala Diecast Toys Cars on eBay 0 07-27-2017 02:50 PM
