Scan Tool Recommendations - Chevy Impala Forums
  • 1 Post By WickedGoat
post #1 of (permalink) Old 04-07-2018 Thread Starter
2014LTDLTZ's Avatar
Quoted: 37 Post(s)
Ok, so here is my poorly-defined question on a Saturday morning. Looking for suggestions for an OBD-II and newer type of scan tool with (at least) the following abilities/attributes:
- not laptop based or smart phone based
- able to not only read error codes, but also able to reset
- covers broad range of systems including ABS
- able to view live data as well as snapshot: voltages, temperature, etc.
- open to additional features I have not mentioned
- price hopefully no more than $250.00
Ok, so open the floodgates of opinions (kindly hold the criticisms - I haven't had my coffee yet). Thanks in advance.
2014LTDLTZ is offline
post #2 of (permalink) Old 04-07-2018
Quoted: 240 Post(s)
Stay away from innova. They do not keep true to their advertising. While the 31603 I have will do all those things you mention plus srs, the software to view the live data on a computer is no longer supported unless you own an auto repair business. When I first got the scanner and downloaded the software I was able to transfer andview my data log on my computer and see everything stored from the car to the scanner, unfortunately innova put out an auto update sometime between then and a couple months ago that rendered the software I had on my computer useless. When I contacted their cs, they said I was pretty well sol unless I owned a shop or was a shop worker. Not the type answer a consumer expects.
The box says right on it as well as their website that you can transfer live data for viewing with their software.
post #3 of (permalink) Old 04-07-2018
WickedGoat's Avatar
Quoted: 141 Post(s)
I've been eyeballing this one...
https://m.harborfreight.com/automoti...ist-63806.html
Fred9505 likes this.
2014 Chevy Impala LTZ Limited
- 5% Window Tint, Rosen GM1210 Stereo, Polk Audio Components and 6x9s, Pioneer, Kenwood amps and sub, Addco Rear Sway Bar, ZZP Strut Tower Braces, LED fogs and low beams, back up and interior lighting, SS dash, stereo and shifter trim.
2004 Pontiac GTO
- Quicksilver on Black 6 speed, garage queen
2004 GMC Yukon SLT
- The reliable back up... can't part ways with it!
2016 GMC Acadia Denali
- Quicksilver on Black, AWD, rear DVD, 2/2/3, nice...
WickedGoat is offline
post #4 of (permalink) Old 04-07-2018
Fred9505's Avatar
Quoted: 46 Post(s)
who woulda ever thunk harbor freight?
Fred9505 is offline
post #5 of (permalink) Old 04-07-2018
hatzie's Avatar
Quoted: 157 Post(s)
I have a clone Tech II but that won't work past 2013 Model Year vehicles.
Give this one a whirl.
https://www.impalaforums.com/diy-how-...scan-tool.html
It's $219 on Amazon shipping included.
2009 Impala SS
hatzie is offline
post #6 of (permalink) Old 04-07-2018
WickedGoat's Avatar
Quoted: 141 Post(s)
It has gotten great reviews and it does alot for what you are paying. Best to catch it on sale and then drop a 20% off coupon on it.
2004 Pontiac GTO
2004 GMC Yukon SLT
post #8 of (permalink) Old 05-02-2018 Thread Starter
2014LTDLTZ's Avatar
Quoted: 37 Post(s)
Thanks to all for your individual and collective inputs.
Anyone have any experience with the Foxwell line of products? Specifically, the Foxwell, NT644? How does it compare to the other units mentioned above? Does it do anything additional (or NOT do anything) the others mentioned do? I do recognize this model is over the previously-mentioned $250 limit, but I have come across a possible purchase for around $300 (not too much above my limit) so I figured I'd ask.
Link to the product:
http://www.foxwelltech.com/product/item-14.html
Usual disclaimer(s): I have no vested interest in the company or product beyond considering buying it for myself to use. Thanks again in advance for all your input.
post #9 of (permalink) Old 05-02-2018
TeeRev's Avatar
Quoted: 124 Post(s)
So, I'm going to throw in my recommendation for the OTC 3208.
It reads and clear codes, as well as ABS. It also has manufacturer specific definitions for most codes! Not only that, it can also check I/M monitors and give you live readouts of your engine parameters such as speed, RPM, temps, throttle position, ignition advance, ABS load, etc. etc. with freeze-frame capabilities.
The best part? It's $60 on Amazon. I upgraded to it to read ABS codes (I had a smaller code reader but it couldn't read ABS), and I couldn't be happier with my choice.
Edit: There is no airbag capability, but that's available on the next model up, the 3209. Don't know all that much about it, so I can't vouch for it but I really like my 3208. Fun fact; OTC tools is a subsidiary of Bosch.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
TeeRev is offline
post #10 of (permalink) Old 05-03-2018 Thread Starter
2014LTDLTZ's Avatar
Quoted: 37 Post(s)
Thanks for the suggestion, TeeRev. Anyone out there have any Foxwell input?
post #11 of (permalink) Old 4 Weeks Ago
Jamessulivan.ap's Avatar
An expensive scanner . This detailed review about Foxwell NT644 Pro may be helpful for you https://www.obdadvisor.com/foxwell-nt644-review/
Jamessulivan.ap is offline
Android based Scan Tool hatzie Chevy Impala 8th Gen Discussion 13 01-12-2019 04:18 PM
Vident iLink450 Full-Service Scan Tool Tesla DIY How To's & Write Up's 4 03-27-2018 07:51 AM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 02-22-2018 12:10 PM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 12-16-2017 10:10 PM
OBDII Scanner Code Reader CAN OxGord MS309 OBD2 Scan Tool Diagnostic RSS Bot Impala Diecast Toys Cars on eBay 0 11-01-2017 12:30 PM
