Low oil pressure light keeps coming on - Chevy Impala Forums
 6Likes
  • 3 Post By hatzie
  • 2 Post By hatzie
post #1 of (permalink) Old 03-18-2018 Thread Starter
aleenahl524's Avatar
Last week or a couple days ago the car DOD stopped working and it stayed and ate cylinder mode it's a 2006 Impala SS and it has 134000 miles on it for some reason now I started it today and I don't hear any lifter tick or rod knock or any noise from the motor that doesn't sound different than normal and the low oil pressure keeps blinking and it keeps saying turn the engine off immediately so what does that mean I heard it was the oil pressure switch and that would cause it to do that the card doesn't do anything until I get a little over a thousand RPM I still don't hear any noises or text I did put some off brand oil in it over a week ago would that cause it would have helped if I get an oil change with new oil filter and all that let me know as soon as possible please this is my only car that me and my fiance have to drive with our 2 babies please help me as soon as possible and get back with me on this issue I would really appreciate it thank you
aleenahl524 is offline
post #2 of (permalink) Old 03-18-2018
terdog10's Avatar
that would be a start change oil pressure switch and make sure no codes, hopefully oil isnt low but i always change oil every 3 to 4 thousand miles
terdog10 is offline
post #3 of (permalink) Old 03-19-2018
hatzie's Avatar
Quoted: 142 Post(s)
Make sure you change the AFM DOD lifter filter screen under the oil pressure switch.
The Oil Pressure Switch or Sending unit GM PN#12616646.
The AFM DOD lifter filter GM PN#12585328
You can get em on Amazon with Prime shipping or your GM dealer.
This is a fellow doing this on an LS4 5.3L in a cousin of our cars the Pontiac GXP.
2009 Impala SS
hatzie is offline
CandiO's Avatar
I am having the same issue with my 2006 impala. I religiously change my oil and my oil light comes on, I get the low oil pressure warning telling me to stop engine, then it goes off again. Stays on for maybe 30 seconds each time, then shuts off. Do I just need to replace the 2 parts mentioned above or will I need a new oil pump also?
CandiO is offline
hatzie's Avatar
Quoted: 142 Post(s)
Depends on what's really happening. The screen and sensor are an easy cheap fix. If the screen is clear and the sensor is working properly it's time to put an oil pump in.
I usually just replace the pickup tube and screen when I do an oil pump.
If your 06 has AFM Displacement on Demand replace the oil pan gasket with the updated GM gasket listed in the LS4 oil consumption TSB 11-06-01-007... even if you aren't using oil.
A Melling oil pump will come with more than one pickup tube O-ring. Pick the right one for your rig according to the instructions.
I use a pickup tube brace or girdle depending on what you want to call it to keep the pickup tube from tilting in the oil pump inlet...
Be sure to properly centre the gerotor in the oil pump housing. Aftermarket oil pumps and even stock GM oil pumps have pretty tight clearances to the gerotor setup so it has to be properly setup to avoid damaging the new pump. There are horror stories of cracked gerotors that could've likely been avoided if the pump housing to gear relationship had been setup properly.
This is a Melling 10295 but it applies to all of the LS engine oil pumps.
Once that's done prime the pump.
2009 Impala SS
hatzie is offline
Quoted: 183 Post(s)
Did you use the correct viscosity oil and an ACDelco oil filter? Some cheap, aftermarket oil filters, will not have the correct oil pressure operating level.
sidemouse's Avatar
Quoted: 8 Post(s)
It could be your oil pressure sender, it could also be the connector, matter of fact it could be as simple as it came loose and someone just needs to plug it back in.
But until someone gets up in there and takes a look we can stand around throwing guesses all day.
sidemouse is offline
is there any reason an oil extractor wont work? luckydriver Chevy Impala 9th Gen Discussion 29 07-05-2018 12:57 PM
2x LASFIT 9006 HB4 LED Headlight Bulb Kit Low Beam 6000K 72W 7600LM White Light RSS Bot Impala Diecast Toys Cars on eBay 0 11-16-2017 03:30 AM
Philips Crystal Vision Ultra 9012 HIR2 55W Head Light Bulb Replace High Low Dual RSS Bot Impala Diecast Toys Cars on eBay 0 11-10-2017 01:10 PM
Universal Low Pressure 5-9 psi Electric Fuel Pump With Installation Kit E8012S RSS Bot Impala Diecast Toys Cars on eBay 0 08-22-2017 08:40 AM
