Impala keeps dying - Page 2 - Chevy Impala Forums
 2Likes
post #16 of (permalink) Old 3 Weeks Ago
Alanb's Avatar
I have a 06 ss has anyone had any problem with a parasitic draw
Alanb is offline
post #17 of (permalink) Old 2 Weeks Ago
Alanb's Avatar
Hot engine slow crank..when the engine is cold it crank up fine..If I drive it to go get gas it cranks really slow.
Alanb is offline
post #18 of (permalink) Old 2 Weeks Ago
Quoted: 363 Post(s)
Then it appears the slow cranking is not due to a low battery (caused by parasitic draw). So I'd say the starter is going bad.
What engine is in your Impala?
Back in the day, slow cranking was common on high compression big blocks. After shutting them off, the motors would heat soak and be very difficult to re-start until they cooled off. But I'm not aware of any such issues with the motors in recent vintage Impalas.
[Edit]One other thought: Inspect the wiring going to the starter and be sure all the connections are clean and free of corrosion. It might be that you have a corroded connection that works OK when it's cool, but has high resistance when it heats up. That's only a theory But before you buy a new starter, you might check the wiring first.
post #19 of (permalink) Old 2 Weeks Ago
Alanb's Avatar
2006 ss 5.3 v8
Alanb is offline
Question about the Key fobs on the 9th gen Impala FAWAZ87 Chevy Impala 9th Gen Discussion 9 05-04-2019 07:58 AM
New Impala Owner 2016 Limited chrisdaboss Introductions & Welcome Forum 15 11-12-2017 06:56 AM
Do the 2018 Impala Premier 2LZ got Automatic Park assist like the 2016 and up Malibu? FAWAZ87 Chevy Impala 9th Gen Discussion 7 10-23-2017 01:03 PM
2015 Impala Limited LT Steering Wheel Controls bcallahan Audio, Video, and Electronics 0 09-19-2017 08:16 AM
2000-2005 Impala Reliability? Rager Automotive Discussion 2 09-04-2017 07:22 PM
