Passenger side rear brakes making a metallic grinding noise - Chevy Impala Forums
 2Likes
post #1 of (permalink) Old 08-25-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
Hello I have a 2006 Impala SS 161k miles
About 2 months ago I had a mechanic replace my brake pads both front and back.
Now the passenger side rear brakes are making a metallic grinding noise... I heard no squealing noise that usually comes with wearing brake pads. Looked at the rotor and there a clear signs of grinding. As well as brake dust/metallic dust on the rim. So I would assume the brake pads are bad.
But how would they get this bad this fast to the point were its grinding the rotor?
Why would only one set of brake pads go out just like that? The rear brakes at that?
Nstaten2 is offline
post #2 of (permalink) Old 08-25-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
Sorry not caliper, I mean rotor
Nstaten2 is offline
post #3 of (permalink) Old 08-25-2016
skippythorson's Avatar
Quoted: 4 Post(s)
Mine are doing the exact same thing, both on the Monte Carlo and the Impala. On the Monte, it seems like when I turn right it's bad. On the Impala, if I turn left, it's faint but noticeable and that's how the Monte started.
I'm thinking it has to be warping or some sort of rust buildup on the inner or outer edge of the rotors themselves. The Monte can give a bad vibration but the Impala is smooth while making a similar sound. Think these cars just eat rotors as candy. Which, if that's the worst it gets, I can deal!
skippythorson is offline
post #4 of (permalink) Old 08-26-2016
1954 Chevy's Avatar
Quoted: 14 Post(s)
Sounds to me like you need to get the mechanic who put on the new pads to check for a bad one. If it makes a grinding noise every time you apply the brakes, there is definitely a problem.
1954 Chevy is offline
post #5 of (permalink) Old 08-26-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
Nstaten2 is offline
post #6 of (permalink) Old 08-26-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
Where you see silver is where it's been grinding at
Nstaten2 is offline
post #7 of (permalink) Old 08-26-2016
Quoted: 353 Post(s)
Looking at the pics, it appears that the pad is worn all the way down to the rivets. Or at least down to the sensor.
Several thoughts on this...
One is that you have a bad master cylinder, but I doubt that's the case. If it fails to suck the piston back when the pedal is released, you could get accelerated brake wear, but I would expect that on more than one wheel.
Two would be that the right rear brake was not bled properly and has air in it which is causing the pad to ride on the rotor thus causing premature wear.
Three would be that the glide pins are sticking, causing the caliper to be biased to one side resulting in one pad wearing (much) faster than the other. (The piston side pad releases, but the other side doesn't move much and rubs the rotor.) I've also seen where too much grease was packed around the glide pin which can also push the caliper to one side.
BTW, Do you see any signs of brake fluid leaking?
My take is either 2 or 3, both of which can cause one pad to get worn while the mating one still looks new. I'd put a new pad on it, bleed it, and inspect the glide pins, making sure the caliper can move freely both ways.
One last thought - what kind of pads are they (ie, material)? Cheap pads can wear extremely fast if there's an issue as described above. You want to be sure your mechanic didn't tell you one type, then put some cheapos on instead.
post #8 of (permalink) Old 08-26-2016
Quoted: 353 Post(s)
It seems like, while keeping all my fleet in service, that we only get the warning squeal from the sensor about half the time. All too often, we don't know about it until they start grinding.
When I put new pads on, I inspect them to be sure the sensor is positioned properly so that it will engage the rotor BEFORE the pad is paper thin. But my kids still bring me cars with chewed up rotors.
I do seem to recall one situation where, when I asked about squealing, one of my kids replied, "It did it for a while, but then it stopped, so I figured it had fixed itself."
Nstaten2 likes this.
post #9 of (permalink) Old 08-26-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
No brake fluid leak... And they were semi metallic brake pads. And thanks for your input. I'm gonna look into that right now.
Also, would it be ok to put new brake pads on the same rotor. Should I have the rotors machined first?
Nstaten2 is offline
post #10 of (permalink) Old 08-26-2016
That Guy!!
worthirt's Avatar
Quoted: 36 Post(s)
Doesn't that seem to usually be the case? Wife does stuff like that to me all the time.
1996 Caprice Classic
worthirt is offline
post #11 of (permalink) Old 08-26-2016
Quoted: 353 Post(s)
In the past, I was a stickler for machining the rotors or replacing them. But as I've gotten more experience (and lazier) I've experimented with just pad replacement, even on a rotor that showed wear like in your pics, and had good results.
I just put new fronts on my 99 Lumina the other day, and one side of one rotor was a bit chewed, but they seem to be working fine. The pedal feels good, and there's no indication of any problems - no pulling to one side under braking, for example. So, I suggest just putting new pads on that one corner (using the same type/brand) and see how it goes.
If it really needs machining and you don't do it, there won't be any catastrophic failures. You'll get some brake noise, and maybe some pulling. That's about all.
And keep in mind, the new brake pad will do a decent job of machining the rotor for you
post #12 of (permalink) Old 08-26-2016
Quoted: 251 Post(s)
I fear the day the wife pulls this one on me....UGH!!!!
Joes74challenger is offline
post #13 of (permalink) Old 08-26-2016 Thread Starter
Nstaten2's Avatar
Quoted: 9 Post(s)
Music to my ears... Appreciate the advice
Nstaten2 is offline
post #14 of (permalink) Old 08-26-2016
That Guy!!
worthirt's Avatar
Quoted: 36 Post(s)
It will happen, trust me.
worthirt is offline
post #15 of (permalink) Old 08-26-2016
Quoted: 927 Post(s)
You may also go through brake pads faster if the rotor is chewed up. Personally, I'd either replace the rotor or have it cut (aka "turned"). Just my opinion though!
1965 impala non ss rear lower passenger side quarter panel trim molding RSS Bot Impala Diecast Toys Cars on eBay 0 04-04-2019 12:52 PM
"wanted" 77-79 caprice classic station wagon passenger side front and rear door lower CARMINE Restoration Forum 0 07-04-2018 11:36 AM
Clicking/Tapping Noise on Passenger Side of Dash Ilovegm Chevy Impala 8th Gen Discussion 21 04-19-2018 07:35 PM
