2015 Impala with Bose - Page 4 - Chevy Impala Forums
 5Likes
post #46 of (permalink) Old 05-02-2017
Killroy2005's Avatar
I am new to the forums. But I have two quick questions. I have the bose sound system in a 2015 impala. The loaded enclosure I plan to put into the car has a low input and a high input. If I just run a wire from the output of the rear speaker coming from the amp to my new amp. While using the high power mode. Will I need the special LOC. I undersrand systems with only a low input need the LOC to step up signal. Thanks in advanced.
Killroy2005 is offline
post #47 of (permalink) Old 03-09-2018
tjhenry77's Avatar
Quoted: 50 Post(s)
Originally Posted by Bdot521 View Post
For those that have successfully installed their setup, where did you route your power wire to the front battery? Im having trouble finding a spot to run the wire.
Hello, I went directly behind the center console thru the firewall, there is a sizable boot there. ( I was able to run a 1/0 awg wire)
Car audio specialist.
tjhenry77 is online now
post #48 of (permalink) Old 03-09-2018
tjhenry77's Avatar
Quoted: 50 Post(s)
that may work, but since it is an amplified system you're tapping into, you really want to get a line out converter, I actually got an audio control lc7i for my car, it can handle amplified signals. I tapped into the trunk 6x9's wires (there's 2 sets on these speakers MAKE SURE to tap the bottom ones).
I'd say try it your way first, and if it sounds crappy, get the LC2i from audio control, that will work great. (the lc7i you want only if you are upgrading everything, like mids/highs)
post #49 of (permalink) Old 03-23-2018
jhosler's Avatar
Originally Posted by Bluetik70 View Post
Hello, I was wondering if the rear deck has holes for 6x9 speakers standard on each vehicle. I know the Bose system has the 6x9's in the rear deck. I was thinking maybe I could add some, if there were already holes for them in the rear deck. And also , is there a remote wire connected to the factory amp and could I splice that wire to run to an amp for a couple of ten inch subs. Thanks to anyone who could help.
Yes, there are holes for the 6x9's in the rear deck. I'll be adding some nice 6x9's in them to add a little more bass to the car.
hi
jhosler is offline
post #50 of (permalink) Old 04-27-2019
twon520's Avatar
hey im new here. i have a 2017 chevy impala Lt, non bose system. i installed a cheap LOC hooked to rockford p3 12 inch subs and a rockford prime 1200.1 d amp. the subs sound ok but at higher volumes they dont sound all that lound. i would think these subs would sound pretty lound. any suggestions on what could be wrong? would the factory amp have anything to do with it?
twon520 is offline
post #51 of (permalink) Old 04-27-2019
tjhenry77's Avatar
Quoted: 50 Post(s)
I had that identical set up.
But it was intensely loud.
This could be many issues.
Fire me a PM with ur cell and Iíll text u thru ideas of what it could be.
It sounds to me ur subs are hooked up correctly
For this to be correct
You MUST make sure your subwoofer models are the p3d4-12 models NOT the p3d2-12
Once thatís verified. Make sure all ur positive wires are connected to positive on spearkers. And same for negative. This sounds to be maybe a phase issue.
On ur subs, are both voice coils connected?? If not. Also could be your issue........ thereís so many more problems it could be
LinkBack to this Thread: https://www.impalaforums.com/audio-video-and-electronics/947993-2015-impala-with-bose.html
Audio, Video, and Electronics on Chevy Impala Forums | BoardReader This thread Refback 07-22-2015 09:29 AM
Buying a used 2015 Impala? Good idea? RandomCruiser Chevy Impala 9th Gen Discussion 31 11-03-2017 06:00 AM
2015 Impala Limited LT Steering Wheel Controls bcallahan Audio, Video, and Electronics 0 09-19-2017 08:16 AM
2015 2016 2017 2018 chevrolet impala parking sensor 2014 chevy impala pdc oem RSS Bot Impala Diecast Toys Cars on eBay 0 09-11-2017 06:40 AM
