Anyone know if a auto-dim rearview mirror will work in 2012 LT - Chevy Impala Forums
post #1 of (permalink) Old 10-17-2013 Thread Starter
Quoted: 931 Post(s)
Can I just buy a GM auto-dim mirror and will it connect right up and work on my 2012 LT? Mine has Onstar functionality and everything, but still has a manual day/night "switch". Can I just power the same type of mirror, but with auto-dim and connect it right up?
Thanks.
post #2 of (permalink) Old 10-17-2013
auntjemima's Avatar
Yes. Its the same plug. Get a mirror with the auto dim and your onstar options and it will all work as you expect.
auntjemima is offline
The Following 2 Users Say Thank You to auntjemima For This Useful Post:
jtrosky (10-17-2013), RyanZ71 (10-19-2013)
post #3 of (permalink) Old 12-07-2013 Thread Starter
Quoted: 931 Post(s)
One more follow-up question - what about the mirrors with the little window that displays compass and temperature information? Will that little display actually work if I put it in my 2012 LT? I'm lookin at used "015607" mirrors on Ebay and a lot of them have that little window - but I don't want the window if it's not going to work.
Also, I've noticed that *most* of these used mirrors have blue and yellow marks on the back - what is up with that? Do they have heat issues or something that caused them to melt in that location??
Thank you!!
post #4 of (permalink) Old 12-07-2013
volume's Avatar
if you got a LT or LTZ the compass and temperature on the cluster the LS does not
volume is offline
post #5 of (permalink) Old 12-07-2013 Thread Starter
Quoted: 931 Post(s)
Yeah, but I'm trying to find out if that information will also display in the little window on the rearview mirror if I replace the mirror with one that has the little window on it... I just don't want that little window to be "blank".
Thanks.
post #6 of (permalink) Old 12-07-2013
volume's Avatar
you what to display the compass and temperature on the cluster to the little window ?
you will need one that access the car information center or data link
volume is offline
post #7 of (permalink) Old 12-07-2013 Thread Starter
Quoted: 931 Post(s)
Yeah, I mean if I get an auto-dim mirror (my main reason for wanting to replace the mirror) that happens to have a window for the temp and compass information, I would want that information to actually be displayed in the window.
I was assuming that it got that information from the cares ECM or whatever (there is an 18-pin connection to the mirror), but now that I think about it, maybe the mirror just has a compass and thermometer built right in the mirror itself?
I just wouldn't want the little window in the mirror to be "blank"...
post #8 of (permalink) Old 12-07-2013
auntjemima's Avatar
I am going to say no. If a stock rear view came with this option and you were trying to replicate that then it might be possible. But if you just want to add that feature in, no it isnt going to work.
Example: I installed a stock DIC (overhead) into my 7th gen and because it didnt come stock the wiring wasnt in the roof and I ended up replacing the entire roof harness...
So, even if the 8th gens DID come with that rear view option, I would be curious as to whether the wiring is there for it.
post #9 of (permalink) Old 12-07-2013 Thread Starter
Quoted: 931 Post(s)
^^Thanks - I would tend to agree that it probably wouldn't work... I don't know what I was thinking above - it wouldn't do any good to put a thermostat in the mirror itself since it is supposed to display the *outside* temperature - not the interior temperature! :-) So, I'm guessing that the mirror uses values from the ECM (or whatever sensor(s) the DIC uses), so I doubt that the wiring is in place in the 8th gen Impalas (never see an 8th gen with the temp/compass display in the mirror).
If anyone knows otherwise, please chime in. If not, I'll just concentrate on a mirror without that little temperature/compass window... It's proving hard to find an auto-dim mirror, with map-lights and On-star controls that is in good condition though, so I may not even do it. It's not that it's "hard" to manually adjust the mirror between day/night settings - would just be nice to have it automatically adjust though... I do wish the 8th gen had auto-dim mirrors and auto climate control - they are about the only "luxuries" that I miss a little...
post #10 of (permalink) Old 12-07-2013
auntjemima's Avatar
If the plug for the 7th and 8th gen impalas are the same I can get you all those features in a 7th gen mirror.
post #11 of (permalink) Old 12-08-2013
Harley fanatic
gearhead's Avatar
I found a 8th gen on ebay for $30. and it works just fine.
2006 Impala 2LT 3.5 auto
2003 Silverado 2500HD 6.6 duramax 6 speed manual
2002 Impala LS 3.8 auto SOLD
2010 Impala 2LT 3.5 auto
2002 Harley FLHTCUI Ultra
1998 Harley FXDWG Wide glide 95th anniversary
1982 Harley FXB Sturgis
PGR Rider
gearhead is offline
post #12 of (permalink) Old 12-08-2013 Thread Starter
Quoted: 931 Post(s)
So you put an 8th gen mirror in a 7th gen? Just trying to confirm exactly what you did...
Thanks!
post #13 of (permalink) Old 12-09-2013
Harley fanatic
gearhead's Avatar
Thanks!
no, I put a 8th gen in my 8th gen
PGR Rider
gearhead is offline
post #14 of (permalink) Old 12-09-2013 Thread Starter
Quoted: 931 Post(s)
So some 8th gens come with auto-dim rearview mirrors?
post #15 of (permalink) Old 12-09-2013
volume's Avatar
Only the LTZ and SS
volume is offline
2012 Impala LT Stereo Replacement reesem_2018 Audio, Video, and Electronics 19 02-23-2019 02:46 PM
Need help with Flowmaster 40s 2012 Impala LT Mitch Hamlin Recent Mods/Weekly Updates 2 09-28-2018 04:23 AM
2012 LT to LTZ fe3 Suspension change over Ziekjake 8th Gen Suspension 8 07-09-2018 07:37 PM
2012 Impala LT power port question DaleB Audio, Video, and Electronics 3 06-10-2018 02:58 AM
Please help with engine noise 2012 LT 3.6 Jeffk426 Chevy Impala 8th Gen Discussion 5 05-01-2018 02:21 AM
