2012 Impala OEM Nav Radio Install - Chevy Impala Forums
post #1 of (permalink) Old 12-18-2012 Thread Starter
bigkickr's Avatar
I installed a factory nav radio into my 2012 impala. Had it flashed for my VIN, almost everything works great. The instructions call for it to be tied into the Vehicle Speed Sensor wire. Everything on the radio works except the turn by turn directions which apparently tapping into that wire corrects. The wire is supposed to on a harness that connects to the EBCM. I was lucky enough to have a GM tech I know print me the wiring diagram for the harness. I then had my car audio guys go to tap into it and it wasn't there! They pinned out the entire harness and every single wire was there as it should be except for the VSS wire. Please help! I'd really love to have the turn by turn working on this radio.
bigkickr is offline
The Following User Says Thank You to bigkickr For This Useful Post:
GET_ARMED (07-25-2014)
post #2 of (permalink) Old 12-18-2012
volume's Avatar
I’m planning to get a navigation in my cay do you have picture?
How much did it cost? What is the part num?
volume is offline
post #3 of (permalink) Old 12-20-2012 Thread Starter
bigkickr's Avatar
One of my older posts has a picture, it's a clean install. I think I paid like $800 for the radio which included the guy flashing it to my VIN. I also sprung for a kenwood backup camera which I highly recommend. Who ever you get the radio from unless it comes with the OEM Nav Antenna spring for that as well. I did not have good luck with the aftermarket GPS antenna but the OEM one I haven't had an issue with since I switched it out.
bigkickr is offline
volume (12-23-2012)
post #4 of (permalink) Old 12-20-2012 Thread Starter
bigkickr's Avatar
bigkickr is offline
volume (12-23-2012)
post #5 of (permalink) Old 12-20-2012 Thread Starter
bigkickr's Avatar
These are the pages I got about the VSS wire. If you happen to actually locate it let me know where you found it.
bigkickr is offline
volume (12-23-2012)
post #6 of (permalink) Old 12-20-2012
volume's Avatar
Were did you put the gps antenna?
volume is offline
post #7 of (permalink) Old 12-20-2012
xxxxxxxxxImpala08SS's Avatar
I been thinking about getting One of these decks or a aftermarket cd player/navi unit. I did not want to mount an antenna inside that could be obstructed, or another external one when there is already the onstar/xm one. I have a fully loaded SS think they wouldnt have cheaped out on the radio! Anyways I was searching for a way to use the factory roof antenna and found this. So I am assuming you could do this with these factory decks too?
Modding Factory Onstar/XM Antenna for Aftermarket GPS - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
xxxxxxxxxImpala08SS is offline
post #8 of (permalink) Old 12-20-2012
volume's Avatar
I found this
http://www.mp3car.com/gps/75346-onstar-antenna-as-external-gps-antenna-2.html
But you did not do this to your car?
If I connect the gps to the onstar antenna will it interfered whit the onstar
This is to much work for me to do. the oem navigation antenna is designed to work under the dash ( that is how gm suv got it)
volume is offline
post #9 of (permalink) Old 12-21-2012
No but I probably will this spring, half them people on that thread you posted are confused as to what that antenna is even used for seems like ha. The antenna on the roof has 3 leads, cell,xmradio, and the onstar. Like the write up I found says it disconnects the onstar. I dont mind I dont use onstar anyways. Yeah you could mount it in the dash like the suv's got, Im just saying you could use the roof antenna if you wanted.
post #10 of (permalink) Old 12-21-2012
volume's Avatar
If you are going to do it take picture let me know how it go
volume is offline
post #11 of (permalink) Old 12-22-2012 Thread Starter
bigkickr's Avatar
I mounted the antenna under the center of the dashboard, it wasn't that hard to do, i didn't even screw it down, once you snap the dash back down it isn't going to go anywhere.
bigkickr is offline
post #12 of (permalink) Old 12-23-2012
volume's Avatar
Did you have to take the defroster vent out or the dash panel?
volume is offline
post #13 of (permalink) Old 12-25-2012 Thread Starter
bigkickr's Avatar
No, I just worked it loose and unsnapped it, then held it up with on hand and slid the antenna into place with the other, make sure you have NOT installed the radio before doing this otherwise you'll never be able to fish that wire coming from the antenna down behind the radio. There is an opening between the vents running down behind the radio that is perfect for running the wire.
bigkickr is offline
volume (12-25-2012)
post #14 of (permalink) Old 12-25-2012
volume's Avatar
you loose the dash?
volume is offline
post #15 of (permalink) Old 12-25-2012 Thread Starter
bigkickr's Avatar
yeah, just get the dash apart from the front, it should just unsnap and you should be able to have enough clearance to slide that antenna in place, just remember to have the radio out when your doing it.
bigkickr is offline
volume (12-25-2012)
2001 Malibu Impala Cavalier Monte Carlo CD Cassette Tape Player Radio OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-21-2017 11:30 PM
2014-2015 Chevrolet Impala Radio Control Panel W/MyLink 8" Touch Screen OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-20-2017 11:52 PM
2012 Chevrolet Impala AC Heater Temperature Control Unit OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-20-2017 06:00 PM
2014 2015 Chevrolet Impala Information Screen w/ Radio Controls 23193948 OEM RSS Bot Impala Diecast Toys Cars on eBay 0 07-18-2017 08:20 PM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 07-15-2017 02:10 PM
