2012 Impala OEM Nav Radio Install - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 12-25-2012
volume's Avatar
Originally Posted by bigkickr View Post
yeah, just get the dash apart from the front, it should just unsnap and you should be able to have enough clearance to slide that antenna in place, just remember to have the radio out when your doing it.
volume is offline
post #17 of (permalink) Old 12-29-2012
xxxxxxxxxImpala08SS's Avatar
Find the VSS wire yet?
xxxxxxxxxImpala08SS is offline
post #18 of (permalink) Old 01-07-2013 Thread Starter
bigkickr's Avatar
I have not, but to be honest with you I haven't had time to look for it either. A friend of mine who works at a dealer talked to one of his mechanics who said the wire might be tucked back along the harness where it was supposed to be wired in to, however to get at it I have to take off the airbox, etc. If I get out of work at a reasonable time today I may go fishing for it. I'll keep you posted.
bigkickr is offline
post #19 of (permalink) Old 05-03-2013
jumpinj0e's Avatar
Was about to buy this unit for $400.. find that wire yet?
jumpinj0e is offline
post #20 of (permalink) Old 08-13-2013 Thread Starter
bigkickr's Avatar
I have not, to be honest I put it on the back burner and really don't think much about it anymore. It's rare I go anywhere that I don't already know where the location is, and if I'm driving I have to use my phone because I'm locked out of the radio nav if the vehicle is moving. I was hoping by now someone else would have jumped in and say they found it or they successfully completed this installation, but so far, at least from what I've seen it hasn't been done.
bigkickr is offline
post #21 of (permalink) Old 09-17-2013 Thread Starter
bigkickr's Avatar
*UPDATE* I had the harness pinned out that is supposed to carry the VSS signal from the Electronic Brake Control Module. GM did not include that wire in the harness. I'm assuming because they never set up the vehicle to have a navigation radio. I put some feelers out to some people I know to see if the vehicle speed signal would still come off of the EBCM if a wire was added to the harness in the correct pin location which could then be tied directly into the radio. Worst case scenario I've been told would be to run a wire from each wheel speed sensor, tie them together, and then tie that into the radio. I'm holding off on that for now, but we'll see what happens.
bigkickr is offline
post #22 of (permalink) Old 09-17-2013
Quoted: 932 Post(s)
I'm curious - why do you need the VSS wire at all to begin with? I've connected two different OEM-look navigation systems to my 2012 Impala and they come with a GPS antenna which works just fine (have "High" accuracy at all times) - why is the VSS wire even needed?
Or am I mis-understanding the whole point of this thread?
post #23 of (permalink) Old 09-17-2013 Thread Starter
bigkickr's Avatar
I installed an actual OEM radio I bought from a salvage vehicle and had it flashed for my VIN. Apparently the turn by turn directions pull and operate from the vehicle speed signal. Everything on the radio works flawlessly with the exception of the audible turn by turn directions and the map engagement while following a route. The map knows exactly where it is, but if I enter a destination and veer off course it won't update itself. Again the is allegedly fixed by tying the radio into the vehicle speed signal which I've been able to find a place to tap into with my vehicle. At this point I'm almost wishing I went with an Advent or another OEM "fit" radio, but I wanted to do it with an actual GM unit.
bigkickr is offline
post #24 of (permalink) Old 09-17-2013
Quoted: 932 Post(s)
Hmm, I just don't understand it... Any GPS system can determine the vehicle speed just by using GPS data that is obtained via the GPS antenna - I wonder why the OEM nav system needs the VSS as well... Go figure.
Anyone have any idea why the OEM nav system would require the VSS signal to begin with?
post #25 of (permalink) Old 09-17-2013 Thread Starter
bigkickr's Avatar
Apparently not, the OEM radio pulls that info from somewhere else in the vehicle. Trust me, I wish it was plug and play.
bigkickr is offline
post #26 of (permalink) Old 07-25-2014
GET_ARMED's Avatar
I love this write up. I need a factory style unit with nav and bluetooth.
GET_ARMED is offline
post #27 of (permalink) Old 07-28-2014
I've been debating throwing an OEM Tahoe unit in...we shall see.
donmateo is offline
post #28 of (permalink) Old 08-27-2014
daytonboi's Avatar
I bought a OEM GM Nav Radio and took it to get it programmed at my local dealer, and they said that it wouldn't let them unlock it, can you tell me what you said or did to get it unlocked?
daytonboi is offline
post #29 of (permalink) Old 08-27-2014
Quoted: 10 Post(s)
Hi daytonboi,
Sorry to hear your dealership is having difficulty unlocking your OEM Navigation radio. Please keep us posted and if there is anything we can look into for you don't hesitate to send a private message.
Amber N.
Chevrolet Customer Care
ChevroletCustomerService is offline
post #30 of (permalink) Old 05-11-2015 Thread Starter
bigkickr's Avatar
Mine came unlocked and was programmed for my VIN when it arrived. I've never been able to successfully complete the install. I can see where I am on the map when I'm driving, but I've never been able to get the VSS signal running to the head unit and this have never been able to fully utilize the navigation system with the spoken turn by turn directions.
bigkickr is offline
2001 Malibu Impala Cavalier Monte Carlo CD Cassette Tape Player Radio OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-22-2017 12:30 AM
2014-2015 Chevrolet Impala Radio Control Panel W/MyLink 8" Touch Screen OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-21-2017 12:52 AM
2012 Chevrolet Impala AC Heater Temperature Control Unit OEM LKQ RSS Bot Impala Diecast Toys Cars on eBay 0 07-20-2017 07:00 PM
2014 2015 Chevrolet Impala Information Screen w/ Radio Controls 23193948 OEM RSS Bot Impala Diecast Toys Cars on eBay 0 07-18-2017 09:20 PM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 07-15-2017 03:10 PM
