Spark plugs - Chevy Impala Forums
 28Likes
  • 3 Post By 1999 White C5 Coupe
  • 1 Post By sheila
  • 5 Post By Bill58
  • 4 Post By Tristate Laurent
  • 3 Post By 12 lt
  • 5 Post By Bowtie396
  • 4 Post By rjayl
  • 3 Post By SFCR
Tristate Laurent's Avatar
Quoted: 4 Post(s)
Spark plugs
Hello guys. Hopefully I'm posting in the right area. I'm changing the spark plugs on my 2014 Chevy impala 2lt. I located the spark plugs that's on the front of the engine. Not sure where the rest are. I'm guessing in the back of the engine. Are they easy to get too. Any input on this topic will be appreciated.
Sent from my SM-G975U using Tapatalk
Tristate Laurent is offline
Quoted: 218 Post(s)
The other three spark plugs are on the firewall side of the engine. They are very difficult to get to.
GMs service manual recommends removing the intake manifold to change the three (rear) spark plugs.
Sometime ago, there was a post on this forum from a member who was able to change the three plugs without removing the intake manifold - with specific instructions on how to loosen the coil boot, raise it, rotate it and remove it - to gain access to the spark plug tube.
I do not have the post bookmarked. I think there is also a YouTube video on how to change the spark plugs on the 3.6L.
Tristate Laurent (4 Weeks Ago)
Quoted: 190 Post(s)
^+1. Search "3.6 spark plug change" using the google custom search top right.
Tristate Laurent likes this.
The Following User Says Thank You to sheila For This Useful Post:
Bill58's Avatar
Quoted: 51 Post(s)
Bill58 is offline
post #5 of (permalink) Old 4 Weeks Ago Thread Starter
Quoted: 4 Post(s)
Originally Posted by Bill58 View Post
Thanks for the feed back guys. I watched the video and believe I can take on that task. I will keep you guys updated.
rjayl's Avatar
Quoted: 32 Post(s)
I would simply remove the upper intake manifold. It is very easy to remove and makes the job so much easier.
rjayl is offline
post #7 of (permalink) Old 4 Weeks Ago
Quoted: 240 Post(s)
There is no reason to remove the manifold. Back plugs on the lfx are not that difficult to get out at all. Have changed them in the 3.6 in our 2012 twice now and the second time took about 30 minutes to change them all. The coilpacks clear with a quarter turn.
The video and post suggested above in post #2 by @1999 White C5 Coupe ;were what initially brought me to this forum a few years back. Should be this one https://www.impalaforums.com/chevy-i...s-done-it.html. Have stuck around since.
etb4u's Avatar
Quoted: 17 Post(s)
A good chance to clean the intake, or put a jacfab spacer on and bigger TB 😆
etb4u is offline
Bowtie396's Avatar
Quoted: 43 Post(s)
The OP stated he has a 2014 2LT (New Generation). The Air Inlet of the Intake is in a different position than that of the previous generation and sits right over one of the Coil Packs. The Previous generation Impala LFX uses a completely different Upper Intake than the new generation Impala. It is near impossible to get the Coil & Spark Plug out on a New Style Impala with out removing the upper intake. It is not hard to remove, takes about 10 minutes.
plano-doug, sheila, Bill58 and 2 others like this.
Bowtie396 is offline
The Following User Says Thank You to Bowtie396 For This Useful Post:
Tristate Laurent (3 Weeks Ago)
post #10 of (permalink) Old 3 Weeks Ago
Quoted: 240 Post(s)
OK, my mistake.
Thought I read where another member here did change plugs on a 9th gen without removing the intake, maybe it was a newer limited model, still seems to be some confusion on what some call 9th gen.
post #11 of (permalink) Old 3 Weeks Ago Thread Starter
Quoted: 4 Post(s)
Guess what. I have to remove manifold in order to to get to the two remaining plugs. Sucks. That's the only way.
post #12 of (permalink) Old 3 Weeks Ago Thread Starter
Quoted: 4 Post(s)
I tried removing manifold. I'm not getting all the screws. Any help would be appreciated. I removed intake.
post #13 of (permalink) Old 3 Weeks Ago
rjayl's Avatar
Quoted: 32 Post(s)
Remove the six(6) bolts shown along with PCV hose, flexible intake tube and electrical connections.
rjayl is offline
post #14 of (permalink) Old 3 Weeks Ago
SFCR's Avatar
Quoted: 13 Post(s)
The intake manifold will have to be removed. See the attachment.
File Type: pdf Repair content for 2014 Chevrolet Impala.pdf (347.5 KB, 12 views)
File Type: pdf Intake Manifold R&R for 2014 Chevrolet Impala.pdf (725.1 KB, 10 views)
SFCR is offline
The Following 2 Users Say Thank You to SFCR For This Useful Post:
1999 White C5 Coupe (3 Weeks Ago)
post #15 of (permalink) Old 2 Weeks Ago Thread Starter
Quoted: 4 Post(s)
In a jam. As I was removing manifold from engine. Trying to get to the spark plugs The hose leading from the coolant reservoir to the engine. The quick connect part broke off. Would anyone have that part number or the name for that part so I can better explain it to the other fools at the auto part store. I believe it's the the overflow hose.
