My Trifecta Tune & a Question or Two.... - Chevy Impala Forums
 6Likes
  • 1 Post By Tx14ImpalaLT2
  • 1 Post By ICUBB
  • 3 Post By ICUBB
post #1 of (permalink) Old 03-15-2019 Thread Starter
Tx14ImpalaLT2's Avatar
Quoted: 5 Post(s)
After considering both the Overkill and Trifecta Tune, I ended up going with the Trifecta. While it was a fairly easy process, there were a few steps that you kind of have to figure out on your own. Overall though, it only took around 15 minutes to install once everything was available.
When you order it, you get your "tune" as an email file (download it first before you start your tune I later learned) and then your Tuner Cable comes a few days later. Most PCs have just random USB Ports so make sure that you're actually plugging the cable into a true USB Port and not just a "Charging Only" one, because it will give you an "Unrecognized" Error which I initially thought meant there was something wrong with the cable itself.
Driving the car after the tune was installed was like driving a completely different car. As one reviewer put it, it felt "lively" and immediately responsive versus the previous feeling of having to wait for the motor to react one you hit the throttle. It's also louder in the intake sound which I really enjoy as well. It is well worth the money and I'd use Trifecta again for any car that I had.
So now I'm ready for the next stage of upgrades. Has anyone installed the Overkill Simple Intake & 80mm Throttle Body with a Trifecta tune? If so, will it throw a code? Or is not really worth getting the Intake and I should just go with the 80mm Throttle Body and a drop-in K&N Air Filter?
I'm also planning on adding the JacFab Intake Spacer and (if it seems to also make sense), the Ported Intake. As far as I can see, that seems about it for these cars as I haven't found anything regarding Cams, etc and I've yet to hear an aftermarket 3.6L exhaust sound anything but raspy.
Any feedback would be appreciated. Thank you!
[email protected] likes this.
2014 Chevrolet Impala LT2
Trifecta Tune
Primary Y-Pipe Mod
Magnaflow Mufflers
K&N Drop-In Filter
20" Centerline Wheels
Custom Vintage "SS" Stripes
Tx14ImpalaLT2 is offline
post #2 of (permalink) Old 03-16-2019
ICUBB's Avatar
Quoted: 109 Post(s)
Any modifications to the car would require a retune. Otherwise the aif/fuel ratio will be messed up and may actually lead to a decrease in power and response. Trifecta does offer Advantage+ and Elite version of the tune, not sure which you purchased. I only have the standard tune here as I only have stock parts but from what I gather if you have either the Advantage or Elite you can data log and send them the results and they will do a custom tune. You would have to contact them for more info than that.
Just a resident noob.
ICUBB is offline
post #3 of (permalink) Old 03-16-2019 Thread Starter
Quoted: 5 Post(s)
Thank you. Appreciate the info. I'll upgrade to the better level of tuning so I can add these.
Trifecta Tune
Primary Y-Pipe Mod
Magnaflow Mufflers
K&N Drop-In Filter
post #4 of (permalink) Old 04-01-2019
birdman9177's Avatar
Quoted: 9 Post(s)
can you notice the diffrence in your vehicle after you added that? i was thinking about getting the one you have as i have all stock parts.
birdman9177 is offline
post #5 of (permalink) Old 04-02-2019
ICUBB's Avatar
Quoted: 109 Post(s)
Originally Posted by birdman9177 View Post
can you notice the difference in your vehicle after you added that? i was thinking about getting the one you have as i have all stock parts.
Yes absolutely. The biggest difference will be the responsiveness of the gas pedal. I cannot speak of any fuel benefits as I do not track it. Any horsepower gains are minimal but the responsiveness of the pedal will easily make it feel more sporty.
ICUBB is offline
post #6 of (permalink) Old 04-02-2019
Quoted: 9 Post(s)
okay bro thanks for the info appreciate! did you install it yourself? or did you take it somewhere else? if so was it fairlly easy?
post #7 of (permalink) Old 04-02-2019
ICUBB's Avatar
Quoted: 109 Post(s)
It was very easy but you will need a fairly current laptop or surface tablet with usb to do it. Check the requirements on the site. https://www.trifectaperformance.com/...er-guide.html/
ICUBB is offline
The Following 2 Users Say Thank You to ICUBB For This Useful Post:
birdman9177 (04-02-2019)
post #8 of (permalink) Old 04-05-2019 Thread Starter
Quoted: 5 Post(s)
I think the Horsepower increase with the Trifecta Tune is more than just minimal. Trifecta says on their Web Site that you can: " . . yield gains of up to +14 ft-lbs and +20 WHP under the curve (and +14 ft-lbs and +16 WHP peak on 91 octane) to a completely stock Chevrolet Impala 3.6L (LFX) MY2014+. " To me, it feels like every bit of that power increase is there. I've used numerous tuners on numerous cars and the Trifecta Tune has been the first or second best one I've done as far as performance gains.
And as I said earlier, it's more than just a Power upgrade, it's a drivability upgrade. throttle response is almost instantaneous and gear shifts are crisper and quicker. As my first mod to my first Impala, it inspired me to do a lot more with the car to see what I could get out of it. I've since added the JacFab Intake Spacer, a K&N Drop-in Filter and replaced the stock Y-Pipe (the muffler shop I had to do it said the factory setup was the least efficient and most power-robbing design they had ever seen) with a larger, free-flowing and straight-direct Y-Pipe. I've only had those two mods on a for a few days so it's hard to judge them yet, but they definitely feel like they're adding even more oomph to the car's power band.
This is my first Impala and I'm really having fun with it. I plan on adding the 80mm Throttle Body and Simple Intake from Overkill later this summer. I read somewhere that these cars really respond to their upgrades, and I'm a firm believer in that. I raced a friend's stock '17 Impala LT V6 and beat it by almost 2 car lengths and was still pulling away at the end. Good times..........
Trifecta Tune
Primary Y-Pipe Mod
Magnaflow Mufflers
K&N Drop-In Filter
post #9 of (permalink) Old 05-31-2019
modmaster's Avatar
Tx14ImpalaLT2, Would you be able to post a picture of your car showing the SS racing stripes you put on? I'd love to see what they look like.
modmaster
My car is a 2019 Impala LT
modmaster is offline
post #10 of (permalink) Old 05-31-2019
VladThe's Avatar
Quoted: 24 Post(s)
I have 2 1/2 years left on my drivetrain warranty, so I am waiting on even considering a Trifecta type upgrade until I am outside the warranty window. However, I am curious if anyone has thoughts on possible extra wear and tear on the vehicle when using a performance tune like from Trifecta. The argument I have seen is if the manufacturer thought different tune settings would be an improvement, they would already be using those improvements as the stock settings.
VladThe is offline
post #11 of (permalink) Old 08-04-2019
tomwilliamson@hotmail.com's Avatar
Do you use 93 octane or have to use 93 octane with this MOD? Can you revert back to the factory setting?
post #12 of (permalink) Old 08-07-2019
ICUBB's Avatar
Quoted: 109 Post(s)
The numbers on Trifecta's website suggest 91 octane. I'm sure 87 would be fine, might not see as big of a boost though. Reverting back to factory can be done with your backup file (permanent) you create while installing the tune or by enabling the cruise control setting (temporary). As long as you make the backup and save it somewhere it won't get lost there will be no issue in reverting. Just take your time when installing it and if you have questions call Trifecta.
ICUBB is offline
[email protected] (08-07-2019)
Is TRIFECTA a "Canned" Tune? Not really... TRIFECTA TRIFECTA Performance 2 08-04-2019 11:32 AM
2013 LFX Trans Tune HPT Files MonteMikeGTO PCM and Technical Tuning 7 04-15-2019 04:14 PM
I really hate how hesitant the transmission is. Is a tune the only way to fix it? 37865835235 Chevy Impala 9th Gen Discussion 14 10-01-2018 04:21 PM
HP Tuner Question reubenswinks Chevy Impala 8th Gen Discussion 9 03-16-2018 08:56 PM
Car is Leaking Question DJ_Vasquezz 8th Gen Engine Performance 4 01-24-2018 12:50 AM
