P2646 P-train Fault: Rocker Arm Actuator - Chevy Impala Forums
post #1 of (permalink) Old 08-22-2018 Thread Starter
Sawuwaya's Avatar
Quoted: 10 Post(s)
Just got my 2014 Chevy Impala LS 2.5L out of the shop yet AGAIN, for this same fault error. I changed my oil (it was about due, anyway), my spark plugs, and BOTH the INTAKE and EXHAUST assemblies, not more that 10 minutes that I got my car out of the shop the light is back on again. My mechanics never use anything but OE Spec AC Delco parts. (On a side note: For some strange reason both Rocker Arm Actuators were VERY hard to get...IDK why.) He assures me that it is safe to do my job (I am disabled and this is how I get my income.) as a rideshare driver and that it will not stall, but I really really, really like to solve this dilemma.
I do not want to keep exchanging parts if there is no warrant to do so. Anybody run across this issue beside myself? Short of taking it to an actual GM dealer, which will cost me more money, my mechanic shops that I use are all ASE certified and been in business for 20+ years. What can I try or do?
Thanks...
Sent from my SM-G935P using Tapatalk
Sawuwaya is offline
post #2 of (permalink) Old 08-24-2018 Thread Starter
Sawuwaya's Avatar
Quoted: 10 Post(s)
Is there anyone that can help me with my dilemma, please? Thanks.
Sawuwaya is offline
post #3 of (permalink) Old 08-24-2018
cj1
cj1's Avatar
Quoted: 14 Post(s)
Out of manufactures warranty?
cj1 is offline
post #4 of (permalink) Old 08-26-2018
Bart77's Avatar
Quoted: 37 Post(s)
I have not seen this issue yet on the 2.5L engines, but the 3.6L engines with variable cam lift has had issues with bad rocker arms and solenoids/valves in the valve covers.
What are the "INTAKE and EXHAUST assemblies"? Is it safe to assume that they are the intake and exhaust rocker arm actuators you mentioned later on in your post? If so those were one possibility. If I was going to gunshot a part without actually diagnosing the problem those probably would be the ones I'd do, plus a LOF with the correct viscosity Dexos full synthetic oil witch for the 2.5L engines is a 0w20 oil, (I know it sais 5w20 on the cap but 5w20 Dexos oil does not exist as GM discontinued that weight years ago).
The other issues that it could be are the air bleed valves in the valve cover could be leaking or worn, the rocker arms may have damaged or stuck locking pins. in either case the valve cover will need to be removed for further inspections.
Bart77 is offline
post #5 of (permalink) Old 08-26-2018 Thread Starter
Sawuwaya's Avatar
Quoted: 10 Post(s)
Yes. Engine has (of this posting) about 113k plus.
Sawuwaya is offline
post #6 of (permalink) Old 08-26-2018 Thread Starter
Sawuwaya's Avatar
Quoted: 10 Post(s)
I have used Mobile 1's 5w-20 (75K plus)High Milage for ALL my oil changes since I bought the car used in 2016 with 40.6k on the engine.
Second, to answer your question, yes, both intake and exhaust. One of my mechanics (of 2 my family members used for quite a few years and will not snowball me ) replaced both with new (and he told me that a "version 1" of the actuator set had "issues" and that they remade/reconfigured them and now they sell a "version 2" which is better. I am not totally convinced that the intake actuator was not out-of-the-box "bad", But my experience with cars are almost non-existent. Reason: the Check Engine light was off the day it was replaced and a few hours there was no light and all seemed fine... but then it went back on...and STAYED on since. I am pondering whether or not the intake was faulty and the exhaust did not need replacing.
Damaged or stuck valves? Expensive to replace and diagnose?
Also, it was almost time anyway, according to the OLM and overdue for spark plugs (thanks to that other member that responded to my questions)..
By the way, excuse my ignorance, what does LOF mean, please? I do not utilize a lot of acronyms within responding to different forums.
I REALLY DO want to thank you guys for all your help. Really.
Sawuwaya is offline
post #7 of (permalink) Old 08-26-2018
Bart77's Avatar
Quoted: 37 Post(s)
5w20 Mobil one should good. A "LOF" just means Lube Oil Filter. Basically just an oil change. These days there isn't much to "lube" since most vehicles don't have lube points, aka grease zerks, on suspension or steering components anymore at least from the factory. Sorry for any confusion. And in this case I may have "jumped the gun" so to speak because I was thinking of one set of solenoids that are quite common to fail on these engines but in reality what is involved is a different solenoid that doesn't fail a lot. No offence to your tech but this common failure may have fooled your tech as well.
After looking into what parts are involved with this system and from what you just typed I do believe that your mechanic did replace the wrong solenoids. The updated solenoids are for the intake and exhaust camshaft actuators, that control the valve timing by either advancing or retarding the exhaust or intake cams individually.
The issue your car has is for the Intake rocker arm lift control witch is a different solenoid valve. It operates the intake valves only, commands high or low valve lift and is attached to the valve cover just behind the oil filler cap. On rockauto.com it's called a rear oil control solenoid and a Dorman one costs $53.79 as of this typing, an original equipment, OEM, one may be around $100 or so? But your cost may vary. If it happens to be the intake rockers it can get expensive since those are more labor intensive to replace and I do not know the cost of the rockers since rockauto doesn't list them. I would imagine they are very expensive though.
Bart77 is offline
The Following User Says Thank You to Bart77 For This Useful Post:
Sawuwaya (08-27-2018)
post #8 of (permalink) Old 08-27-2018
melisia's Avatar
check your gas cap
melisia is offline
post #9 of (permalink) Old 08-27-2018
cj1
cj1's Avatar
Quoted: 14 Post(s)
+ Bart77 needs to be verified what solenoids were changed.
cj1 is offline
post #10 of (permalink) Old 08-27-2018
Bart77's Avatar
Quoted: 37 Post(s)
I asked around the shop and nobody had an Impala 2.5L with this issue. But one did have a Malibu with this issue once and they changed the oil control solenoid and all was well. I would check power and ground at that solenoid, if ok i would change the oil control solenoid valve assembly (people with Honda's would call it a VTec solenoid). More than likely the intake rocker arms are ok.
Bart77 is offline
post #11 of (permalink) Old 08-28-2018 Thread Starter
Sawuwaya's Avatar
Quoted: 10 Post(s)
Thank You Bart.
It sound like that oil control solenoid is the lesser of two evils?
I have driven my car over the weekend doing my job and my car felt, shifted and drove fine without warrants. However, I do not want things to go further south than than they already are. Just because it is "working" fine now, what will happen if I do not replace or fix the issue right away? Can I still drive it for now? Will it hurt my vehicle if I continue to drive it? I do not want it to stall on me going down the road or ruin my engine further. Plus, I am trying to get the money to pay for it to be fixed...so I need my car to do it...
Cheers!
Sawuwaya
Sawuwaya is offline
New OEM Rocker Arm Oil Control Valve - 2014-2015 Impala, Malibu 2.5L (12633613) RSS Bot Impala Diecast Toys Cars on eBay 0 05-16-2019 04:44 AM
2007 Chevy Impala: Rear Valve Cover Removal impalaselfmechanic Chevy Impala 8th Gen Discussion 16 03-16-2019 04:10 PM
2007 impala 3.9 l. Rocker arm order Jcast "DIY" Do it yourself/how to 0 11-25-2018 11:50 AM
Drivers side actuator and blend door actuator question. 2000UsedImpala Chevy Impala 7th Gen Discussion 7 06-19-2018 03:07 PM
