Intermittent Bad Gas Pedal Response - Chevy Impala Forums
 2Likes
  • 1 Post By jtrosky
  • 1 Post By 12 lt
post #1 of (permalink) Old 07-27-2018 Thread Starter
greggash's Avatar
Quoted: 5 Post(s)
Angry Intermittent Bad Gas Pedal Response
Hello all, its been a while but here is a question:
has any one else had a gas pedal response issue.
My Car, short history
when I first got the car it was reluctant to go over 42 mph, had to about floor it to make it go.
Then I realized that if I manipulate the pedal a few times, full stroke before starting, its a totally different car, Fast, shifts like magic, 0-60 faster than it should be...etc the car I basically wanted day 1.
well, Today I would say That this issue got much worse. 3 times in one day, I went to pass, change lanes, whatever, and when I hit the gas , there was nobody home, no signal sent to open the throttle, suddenly I am basically idling when I NEED to accelerate....
in a nut shell, today while driving I tried to accelerate and there was zero response, had to lift and reapply the pedal to accelerate.
Thank you all in advance
Gregg
P.s. my car is still under warranty, but bringing it to the dealership is scary, they do not have my best interests at heart. at all.
asked them to patch a tire, the plugged it.
if the test method of the part is to have some mechanic drive my car like a nut, please tell me so I will just buy a new part and do it myself, I don't want them to damage my car any further.
Gregg
greggash is offline
post #2 of (permalink) Old 07-27-2018
SylenThunder's Avatar
Quoted: 5 Post(s)
I've seen this happen on some cars where the ground to the trans deteriorated. Might also be a vacuum line issue. Usually happens on older cars, but you said yours is still under warranty.
Any codes or check engine light?
SylenThunder is offline
post #3 of (permalink) Old 07-27-2018
Quoted: 930 Post(s)
Have you checked to see if you have any stored codes? Could even be something like the gas pedal sensor (gas pedal and sensor are one piece, you basically just replace the gas pedal, which just unbolts).
post #4 of (permalink) Old 07-27-2018
Quoted: 232 Post(s)
Gregg
Tires are not covered under the warranty, surprised they even plugged it for you.
If there is another chevy dealer close, might try taking it to a different dealer. The pedal issue could be dangerous and should be taken care of.
post #5 of (permalink) Old 07-27-2018 Thread Starter
greggash's Avatar
Quoted: 5 Post(s)
I was going to pay to have the tire patched correctly, surprise! they did what they wanted.
I think I may go to a cadillac dealer, its GM.
greggash is offline
post #6 of (permalink) Old 07-27-2018
ICUBB's Avatar
Quoted: 109 Post(s)
Try disconnecting the battery for an hour, it will reset the ECM/TCM, it likely has created your profile as a slow driver. Resetting it should bring the response back to stock for a few trips until it re-adapts to your style of driving.
Just a resident noob.
ICUBB is offline
post #7 of (permalink) Old 08-09-2018 Thread Starter
greggash's Avatar
Quoted: 5 Post(s)
its a 15 bought in 16, warranty till Jan 19th 19
I spoke to my son, he is a Sevice writer at Cadillac (its GM), in general the failure would have to be recreated ( a severe beating for my car that only has 12K miles) So I decided to just replace it myself.
I found the part for $55.
and its just one 10mm bolt holding it in,
and a red slider on the connector that locks it on.
Too easy.
Now its off for a test ride, idle and general pedal response in park seemed normal.
and yes, I will check the car for any codes that may be there but no engine light yet.
and I also received a recall notice for fuel tank purge solenoid , but it seems to run fine right now.
greggash is offline
post #8 of (permalink) Old 08-09-2018 Thread Starter
greggash's Avatar
Quoted: 5 Post(s)
Wink New pedal in place
Hi ;
The new pedal is in. it is very responsive as compared to the original
The car now shifts better and feels much more responsive.
I checked the car for any codes, there were none.
Thank You to the Community
Gregg
greggash is offline
The Following User Says Thank You to greggash For This Useful Post:
TSS (08-13-2018)
post #9 of (permalink) Old 08-09-2018 Thread Starter
greggash's Avatar
Quoted: 5 Post(s)
Replace the pedal unit GM PN#13237352
checked for codes, none there
and it now feels much better, not lazy.
Thanks in advance
Gregg
greggash is offline
1958-1967 GM Accelerator Pedal. Gas Pedal | Skylark GS Chevelle Impala Cutlass RSS Bot Impala Diecast Toys Cars on eBay 0 11-28-2018 12:17 AM
Groaning gas pedal Lizzamama21 Autocare and Maintenance 1 10-16-2018 08:54 AM
1958-1967 GM Accelerator Pedal. Gas Pedal | Skylark GS Chevelle Impala Cutlass RSS Bot Impala Diecast Toys Cars on eBay 0 10-02-2018 12:00 AM
1958-1967 GM Accelerator Pedal. Gas Pedal | Skylark GS Chevelle Impala Cutlass RSS Bot Impala Diecast Toys Cars on eBay 0 09-28-2018 02:00 PM
Gas Pedal Hard to Push Seabiscuit11 Autocare and Maintenance 0 11-06-2017 07:12 PM
