2014 Impala 2lt transmission fluid and filter change - Chevy Impala Forums
9th Gen Drivetrain Transmissions, Clutches and Axles.
  • 1 Post By 12 lt
post #1 of (permalink) Old 08-27-2018 Thread Starter
impala2lt's Avatar
Quoted: 12 Post(s)
So my impala is ready for an early fluid and filter change. I saw somewhere that the filter is internal on these and not accessible? Also, flushes are bad correct? Any good instructions on changing the fluid?
impala2lt is offline
post #2 of (permalink) Old 08-28-2018
Quoted: 240 Post(s)
The 6 speed coupled to the 3.6 is a simple drain and change. Drain plug can be accessed from the driver side without even putting the car on ramps. Would suggest trying to catch the old fluid and measure how much you drained, then put back in as much as drained out.
There is no accessible trans filter.
post #3 of (permalink) Old 08-28-2018 Thread Starter
impala2lt's Avatar
Quoted: 12 Post(s)
where exactly is the drain plug?
post #4 of (permalink) Old 08-28-2018
Quoted: 240 Post(s)
Scroll to post 13 in the link https://www.impalaforums.com/chevy-i...rain-plug.html. If you go in from drivers side in front of the front tire it is pretty easy to reach.
post #5 of (permalink) Old 08-28-2018 Thread Starter
impala2lt's Avatar
Quoted: 12 Post(s)
This applies to the 2014+(new body style) too?
post #6 of (permalink) Old 08-29-2018
Quoted: 240 Post(s)
If it has the 3.6 and 6 speed, my understanding is that it should be the same. I however have not looked first hand under the newer body style.
post #7 of (permalink) Old 09-06-2018 Thread Starter
impala2lt's Avatar
Quoted: 12 Post(s)
It worked. The tiny bolt pictured ended up being the drain plug, which is weird. I saw another bolt on the transmission that looked like it should have been the drain plug. I wonder if it would also work...? Thank you!
post #8 of (permalink) Old 09-06-2018
Quoted: 932 Post(s)
Only one drain plug on the trans. Not sure what other bolt your are referring to - would be curious to see a picture if you manage to get one....
jtrosky is online now
birdman9177's Avatar
Quoted: 10 Post(s)
at what mileage did you change it?
birdman9177 is offline
Get rid of it! jayawest Chevy Impala 9th Gen Discussion 19 04-25-2019 01:31 PM
TH400 Transmission Refresh DesertXL Chevy Caprice 2 04-11-2019 07:56 AM
2005 impala transmission and fluid Robbie Wilson Automotive Discussion 0 10-07-2018 03:34 PM
06 4T65e Trans fluid change? Potator Autocare and Maintenance 4 10-03-2018 12:14 PM
