Hub Help - Chevy Impala Forums
9th Gen Drivetrain Transmissions, Clutches and Axles.
post #1 of (permalink) Old 09-14-2017 Thread Starter
pfc1's Avatar
Hub Help
I thought I would share my experience for the benefit of others on front and rear hub issues. My wife drives a 14 LT, she informs me that her ABS/Traction control light is on...oh boy here we go. Get out the scan tool R/F speed sensor. 59000 miles and speed sensors are failing.... really. My son works for a dealer and he puts it on his scan tool and it shows the wave pattern for the left front bad....1st issue. OK price check and shop around for wheel hubs. by the time i get the replacement which was about a week, the stabilitrac is on and now the power steering is not working. for you do it yourself people all of this happened because of the speed sensor in (or in this case on the hub). New design from GM's masterminds, the speed sensor, tone ring reluctor wheel...MAGNET is glued to the back of the bearing, not internal, no pigtail or wire. The sensor bolts into the spindle on the new design. Change the hub...clear the codes... LR speed sensor no good. Frustrating that the computer would not show both at one time and same hub fits all 4 corners as info. Now you can see the sensor on the back wheel looking in from the back side but not the front, that one needs to be removed to see that it's broken. The magnet is about 1/16th thick, 1/4 in wide and the diameter of the bearing. I'm not sure what would cause these to break but they are exposed. I just thought i would share my experience, maybe it will help other with multiple lights and confusion...and AGGRAVATION !!!
Paul
pfc1 is offline
post #2 of (permalink) Old 10-23-2017
Maven76's Avatar
Quoted: 80 Post(s)
The magnetic sensor strips typically fail due to corrosion jacking(rust build up under the edge of magnet) or sometimes thermal shock like driving through a puddle or similar.
Be aware when replacing hubs that the 3 bolts that hold each hub on are a one time use bolt, as is the lower shock bolt and outer bolt on the upper control arm in the rear.
If you reuse these bolts and torque them to spec they can fail instantly, or worse yet, they can fail later down the road while driving.
GM World Class Technician
Im just here for the cookies
Maven76 is offline
(2) Rear Wheel Hub Bearing & Hub Assembly for Chevy Impala Pontiac Grand Prix RSS Bot Impala Diecast Toys Cars on eBay 0 05-01-2019 10:22 PM
(2) Rear Wheel Hub Bearing & Hub Assembly for Chevy Impala Pontiac Grand Prix RSS Bot Impala Diecast Toys Cars on eBay 0 04-28-2019 11:21 PM
2014 LTZ Wheel Hub Replacement apguy Chevy Impala 9th Gen Discussion 14 01-05-2019 02:17 PM
Hub Assembly Time-Removal Questions Carbide Chevy Impala 8th Gen Discussion 9 10-14-2018 07:06 PM
Front Hub Bearing R&R WickedGoat DIY How To's & Write Up's 0 07-29-2018 07:22 AM
