2015 Impala transmission slipping - Page 2 - Chevy Impala Forums
9th Gen Drivetrain Transmissions, Clutches and Axles.
post #16 of (permalink) Old 10-13-2016
Angus576's Avatar
Quoted: 61 Post(s)
I have read that many people notice this transmission slip. My 2015 V6 does the samething and I don't have a tune. If I drive like an old man I won't see it, if I drive aggressively I may notice it but if I drive normally I see it all the time. I think it's how they programmed the transmission software. If not then it's an issue GM will ignore until it becomes a major issue and force a recall.
Let us know what the dealer discovers if anything.
Angus576 is offline
post #17 of (permalink) Old 10-13-2016
reubenswinks's Avatar
Quoted: 89 Post(s)
Lets hope that's how the transmission is programmed. Although it sounds identical to the first symptoms I got when the 35r wave plate went in my wifes G6 with the 6 speed.
reubenswinks is offline
post #18 of (permalink) Old 02-14-2017
salsaman06's Avatar
I have a 2017. picked up brand new with 20 miles on the odo. I have a 2-3 slippage on occasion when the trans is cold. And strangely like someone else posted, when I turn left. It briefly allows the engine to rev up about 200 rpm during the shift. the 2-3 and 3-2 shift is definitely ....screwy. Haven't taken it to the dealer yet because I cannot consistently reproduce it.
2017 Impala Premier - Silver Ice
All available options
salsaman06 is offline
post #19 of (permalink) Old 07-27-2018
57chevythunder's Avatar
-and for whatever it is worth,,, our 2015 2LT, 3.6, etc, has always had an "odd feeling" 2 to 3rd gear shift since the day it was brand new. It occurs under light throttle, and to me it feels exactly like the second gear clutch is staying applied slightly too long after the third gear clutch applies. (it gives you a "delay" feeling, even to the point of feeling like the engine slightly loosed power during that 2-3 shift) Ours certainly doesn't feel anything like a "slipping" situation. I don't think it does this under hard acceleration, but I'll have to try that. It certainly does it with a cold engine/transmission, but I think not so much when everything is up to normal operating temps.
I agree that is probably a "programming" issue of some sort, especially since this transmission is totally computer controlled. -or I should say controlled by too many computer inputs? I really doubt it is any sort of mechanical issue,,,,
Has anyone got any more answers yet??
Thanks.
57chevythunder is offline
post #20 of (permalink) Old 07-28-2018
Driftwood's Avatar
Quoted: 5 Post(s)
Thanks.
No answers, but same problem with 2017, LT, 3.6
Bill
Driftwood is offline
post #21 of (permalink) Old 05-16-2019
elektrosoundwave's Avatar
I'm glad it's not just me. I get it going from 1st to 2nd every so often. Higher speeds, I might have a little bit of hesitation, but it's the most noticeable 1st to 2nd. Temperature doesn't matter.
2018 Premier with 40,600 miles on it currently.
<Insert Inspirational Quote Here>
elektrosoundwave is offline
post #22 of (permalink) Old 05-19-2019
2016 Impala LTZ's Avatar
Quoted: 25 Post(s)
My 2016 LTZ does the same thing and I also noticed it happens more if I am taking a left turn. Very strange and it has done it since day 1, dealer tells me it is normal so I just live with it. It doesn't do it all the time, very hard to recreate it.
2016 Impala LTZ is offline
post #23 of (permalink) Old 05-19-2019
Jeepster09's Avatar
Quoted: 9 Post(s)
Ok....with all this Trifecta talk, does [or can it?] using Trifecta tune out the speed limiter at 112 mph?
Jeepster09 is offline
post #24 of (permalink) Old 05-19-2019
ICUBB's Avatar
Quoted: 107 Post(s)
I haven't tried to go that fast but I'm pretty sure it does. Best thing would be to ask Trifecta directly tho.
Just a resident noob.
ICUBB is offline
The Following 2 Users Say Thank You to ICUBB For This Useful Post:
Jeepster09 (05-19-2019)
post #25 of (permalink) Old 4 Weeks Ago
Jeepster09's Avatar
Quoted: 9 Post(s)
Thanks, I contacted Trifecta and yes it will re-calibrate rev limiter [speed limiter]. They will re set limiter to match tire speed rating. Mine are at 130.
Transmission Slipping kylek567 Chevy Impala 8th Gen Discussion 18 08-19-2018 06:08 PM
Buying a used 2015 Impala? Good idea? RandomCruiser Chevy Impala 9th Gen Discussion 31 11-03-2017 06:00 AM
2015 Impala Limited LT Steering Wheel Controls bcallahan Audio, Video, and Electronics 0 09-19-2017 08:16 AM
2015 2016 2017 2018 chevrolet impala parking sensor 2014 chevy impala pdc oem RSS Bot Impala Diecast Toys Cars on eBay 0 09-11-2017 06:40 AM
