FYI: There is a TSB on this issue and GM is well aware of it. I was advised it is the double wall of the y-pipe and there is no fix. They "can" replace the y-pipe, but new y-pipe has same design with potential for same issue. Goes away relatively quickly once car is started and moved a little, but I agree, annoying just the same.
My '14 LTZ Limited has done it since I bought with 8900 miles on it, but have decided to just deal with it if GM doesn't have a good fix or better y-pipe solution...
Actually, not sure if it is considered a "TSB" or something else, but here is the wording I got from the Service Manager at local dealership, finally:
2014 Chevrolet Impala Limited (VIN W) [2G1WC5E30E1101187] | Impala Limited Service Manual 7132776 | Document ID: 3671083
#PI1138: Rattle/Noise from Front or Rear of Vehicle on Cold Start Up - (Dec 20, 2013)
Subject:
Models:
2012-2013 Chevrolet Impala
Condition/Concern
Some customers may comment on a brief rattle or noise heard from the front or the rear of the vehicle on a cold start up.
This may be caused by the “Y” pipe inner and outer components expanding at different rates resulting in the rattle/noise.
Recommendation/Instructions
This is a normal characteristic of the vehicle’s exhaust system and no repair(s) should be attempted for this concern.
Customer Information
Please communicate to the customer this condition is a normal operating characteristic of their vehicle. It will not impact the designed performance or reliability of the vehicle. Please share this information with the customer, including a copy of this message.
For further information, please contact GM Technical Assistance Center (TAC) for assistance.
Eric
2016 Silverado LT 4x4
2014 Impala LTZ Limited
- Current Modifications:
- Trifecta, Addco rear sway/MOOG end links, Energy Suspension front sway bushings/MOOG end links, Elite Catch Can, Tinted windows, Dipped Bowties, Curt hitch, GMPP STB's/Don Rome brackets, GM Splash Guards, GM Exhaust Tips, WeatherTech DigiFit floor liners, Winter: Sport Edition P2 with Blizzak's
