2003 Impala cooling fans not coming on - Chevy Impala Forums
 2Likes
  • 2 Post By Bart77
post #1 of (permalink) Old 10-13-2017 Thread Starter
Maddogtito's Avatar
2003 Impala cooling fans not coming on relays check out temp sensor replaced with an auto zone one and suggestion would help
Maddogtito is offline
post #2 of (permalink) Old 10-14-2017
Bart77's Avatar
Quoted: 37 Post(s)
Check the fuses, if ok then check for good power and ground at the cooling fan wire harness connector at the cooling fan. you can do this by connecting a test light between the cooling fan terminals, start the car and turn on the A/C. When the a/c is turned on the cooling fans are also turned on and the test light should light. If it does you need a new fan. If it doesn't you need to check the wiring for an open somewhere.
Bart77 is offline
Slight wobble in front after tire change-- 2003 Impala ls Ian___Impala Chevy Impala 6th Gen Discussion 2 04-22-2018 03:41 PM
Cooling Fans Not Working hg3300 Chevy Impala 7th Gen Discussion 5 11-29-2017 06:25 AM
2003 Chevy Impala LS V6 3.8L Excellent Condition $2,650 Impala2003! Private For Sale Classifieds 0 11-15-2017 09:50 AM
ALUMINUM SHROUD FANS OF RADIATOR+2x12" FANS FOR CHEVY CHEVELLE/ IMPALA 63-68 RSS Bot Impala Diecast Toys Cars on eBay 0 07-16-2017 05:21 AM
