LFX JacFab 3/4" Intake Spacer - DYNO TESTED - Chevy Impala Forums
post #1 of (permalink) Old 09-30-2015 Thread Starter
ImpalaLFX13's Avatar
Quoted: 30 Post(s)
Hello friends,
Just arrived from the dyno, and i'm very, very please with the results.
I'm a bit sad I did loose a bit under 3,300rpm, but the gains from 3,890 to redline is worth it. Also, does not really matter if you compare the power gains vs. the stock wheel power. I'm sure more gains can be achieve with another data-logged with Trifecta and eliminate the bottom-end power loss.
Again, please understand, this test report was done on a Mustang Dyno and the test was compare hot vs. hot/ JacFab vs. previous mods, basically apples to apples. I'm not sure what the gains would be on a stock/no tune engine.
Peak WHP JacFab: 256whp w/o: 251whp (+5whp)
Peak WTQ JacFab: 237wtq w/o: 226whp (+11wtq)
MAX POWER GAINS: +15wtq @4,635rpm/+11whp @5,580rpm
FYI, we did a cold pass by cooling the car 45 minutes;
261whp (259whp without the spacer)
247wtq (241wtq without the spacer)
254whp & 237wtq semi-cold run/ no spacer (did not have time to test with the spacer)
To this day, I'm still shock how the LFX on the Impala responds to modifications, and the power gains always makes doubt the dyno operator and he always make multiple passes to confirm the power. And if you look at my last post :JacFab Track Tested, it allows me to run consistent passes, one after the other one by reducing the engine heat soak (win-win situation)
Enjoy, and i'm very happy for Jason (JacFab) and Overkill (vendor) and Will_P (the only one I know who install this part)
Name:	JACFAB DYNO1.jpg
ID:	106601   Click image for larger version
Name:	JACFAB DYNO3.jpg
ImpalaLFX13 is offline
The Following 2 Users Say Thank You to ImpalaLFX13 For This Useful Post:
RacnJsn95 (09-30-2015), will_p (09-30-2015)
post #2 of (permalink) Old 09-30-2015
Overkill's Avatar
Quoted: 6 Post(s)
Great of you to test and great to see gains, Jason will be pleased to hear this!
Computer Tunes for all 7th 8th and 9th Gen Impalas including 3.6 Direct Injection V6, 3800 Supercharged V6, 5.3 LS4 V8 and 3500/3900 V6
www.OverkillTune.com
https://www.facebook.com/GetOverkilled
Email [email protected], message on Facebook or through the forums
Overkill is offline
post #3 of (permalink) Old 09-30-2015
RacnJsn95's Avatar
Thanks for taking the time, and effort to do this. For the most part, I'm pleased with what I see, and it looks like you did a great job of comparison testing hot/hot, etc!
RacnJsn95 is offline
post #4 of (permalink) Old 09-30-2015 Thread Starter
Quoted: 30 Post(s)
Jason, no sweat.
I do the dyno testing the same way I race the car at the track.
1st past: cold run, 2nd past: cold/hot run and 3rd pass: the hot run.
The test report and my track time did confirm that the spacer, on my application, opens the air way and improve mid-to-high-end RPM. The Humidity was at %62 (%6 more than last time) and barometric Pr was at 102.1 (vs.101.0). So i would not worry too much about the bottom-end power loss, it somewhat little vs. the gains.
Thank you and I will keep intouch
post #5 of (permalink) Old 09-30-2015
will_p's Avatar
Quoted: 14 Post(s)
Awesome, I knew the gains were good from what I felt. Great to have some numbers to back or up! Thanks!
will_p is offline
post #6 of (permalink) Old 11-20-2015
Overkill's Avatar
Quoted: 6 Post(s)
Bump, these are instock and available online exclusively from myself at Overkill Motorsport
:: Overkill Motorsports ::
Overkill is offline
post #7 of (permalink) Old 1 Week Ago
YoloOnThesniper's Avatar
I just put on my typhoon cold air intake but I’m one of your YouTube videos, impalalfx13, you said that the spacer would not work well if you have trifecta, even though in that same video you said that u had trifecta currently on the vehicle? So does this mean I shouldn’t get it or should I?
YoloOnThesniper is offline
LinkBack to this Thread: https://www.impalaforums.com/8th-gen-engine-performance/1062345-lfx-jacfab-3-4-intake-spacer-dyno-tested.html
80mm Throttle Body for the LFX - Page 27 - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com This thread Refback 04-30-2017 10:39 PM
80mm Throttle Body for the LFX - Page 30 - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com This thread Refback 04-15-2016 04:51 PM
8th Gen Engine Performance on Chevy Impala Forums | BoardReader This thread Refback 10-04-2015 05:09 PM
AF Dynamic air intake for LFX. irockid86 Chevy Impala 8th Gen Discussion 4 03-14-2018 07:14 AM
