P0024 2012 impala - Chevy Impala Forums
 6Likes
  • 2 Post By Dfelt75
  • 1 Post By Dfelt75
  • 2 Post By jtrosky
  • 1 Post By Dfelt75
post #1 of (permalink) Old 07-02-2019 Thread Starter
Dfelt75's Avatar
I am at wits end with this code.
Vehicle was purchased afew months ago, has 150k on it. Runs fine
So far i have cleaned/swapped both ocv solenoids. Changed oil and filter. Even installed new solenoid...code still returns after about 40 miles.
Oil is full and clean...code comes back faster if i mash on it. 40 or so miles if i baby it.
I have looked for obvious wire shorts/breaks..did not pull back any of the wire loom cover as it seemed very brittle.
Was debating using amsoil engine flush and another oil change but am kind of scared to use the flush.
Any helpful suggestions?
I also have torque pro app and watch the timing advance.
It seem to move by large numbers..ex 35 down to 15..not 34,33,32,31..not sure if suppose to move in those increments or not, i have never used that feature before
Dfelt75 is offline
post #2 of (permalink) Old 07-02-2019
Quoted: 163 Post(s)
Search p0024 top right.
post #3 of (permalink) Old 07-03-2019 Thread Starter
Dfelt75's Avatar
I will ckeck on desk top tommrow...but i have ran into the same problem of past/post user just searching on my mobile...limited results on here and Google.
Another detail i forgot to mention in original post is slight shudder around 1400 to 1600 rpm
Dfelt75 is offline
post #4 of (permalink) Old 07-03-2019
Quoted: 163 Post(s)
Did you search p zero zero 2 4? I get 6 pages of threads/posts. Some people mistakenly think the 2nd character is the letter "O".
post #5 of (permalink) Old 07-04-2019
kbz1960's Avatar
Quoted: 21 Post(s)
On tapatalk this is all I get.
kbz1960 is offline
post #6 of (permalink) Old 07-04-2019
Quoted: 927 Post(s)
For whatever reason, I've found the best way to search the site is to go into chrome/google and type "impalaforums.com p0024" - this will return like 6 pages of results... The search function using Googles search engine just works better than the forums search function....
post #7 of (permalink) Old 07-04-2019 Thread Starter
Dfelt75's Avatar
UPDATE
Car is fixed. No more cel/pending codes or shudder at lower rpm.
So I feel rather embarrassed on this one.
When the code first popped up I watched a video on you tube about it...the guy was replacing the rear ones..and this just stuck in my head.
Bank 1 = rear of engine/near firewall
Bank 2 = front side near radiator
In my mind i was just hearing "exhaust ocv"...Totally disregarding bank1 bank2
Hopefully my aggravation helps somone out
Dfelt75 is offline
post #8 of (permalink) Old 07-04-2019
Quoted: 163 Post(s)
So, what'd you do/replace???
post #9 of (permalink) Old 07-04-2019 Thread Starter
Dfelt75's Avatar
Just the ocv. Good thing about being a tard and cleaning the wrong bank..new seals and super cleaned solenoids
And to help future guest of this problem...the following will be helpful
When you pull the solenoid out..the seal/OR PART OF IT does not come out with it, if it does it broken in two pieces. The seal stays in the head. If part of it come out /black circle ring stuck on solenoid/ , take a utility knife and cut one or two slices carefully to the seal left in the head. Get a new one p#12593717. Best and fastest way is dealership chevy or gmc..my chevy one didnt have it, only like 10$...not a part store around had one...buy in advance. I used a sturdy flat head screwdriver to pop it out of the head after cutting it. Be careful not to drop anything in the head while doing this...it was a pain in the ass.
I guess i could also suggest to maybe spray the solenoid area with some penetrating oil before attempting to remove them to keep them from breaking. I didnt even think of it while i was working on it...could have possibly saved a few bucks
Dfelt75 is offline
post #10 of (permalink) Old 07-05-2019
Quoted: 927 Post(s)
Interesting. I've personally never ever heard of an "ocv" (had to look it up - "Oil Control Valve").
Where are they located and how hard were they to replace?
sheila and kbz1960 like this.
post #11 of (permalink) Old 07-09-2019
Jonathan Nicholes's Avatar
the code is for "Exhaust Camshaft Position System Performance Bank 2". Their is a TSB out for changing the Exhaust Camshaft Position solenoid valve with a longer service part depending on the engine code on the EUN sticker. If the numbers do not match up on the sticker to what's noted in the TSB then it could still be the solenoid valve or the mechanical camshaft position actuator, or low oil level. Will need a tech2 to actuate the solenoid valve to find out if it's working right. Good thing your still under the bumper to bumper warranty.
Jonathan Nicholes is offline
post #12 of (permalink) Old 07-09-2019 Thread Starter
Dfelt75's Avatar
UPDATE TO MY UPDATE
So the p0024 is long gong..yet i still do have the shudder..at 40mph and 60 mph..light load.
I replaced the old spark plugs. .toast...gap was like .50....ideals better but still shit for the shudder...
Read and read...sounds like its the torque converter. Im going to cheap out/smart out and do the drain and fill three times over about the next 2000 miles.
Will keep you all updated
Dfelt75 is offline
post #13 of (permalink) Old 07-11-2019
SAAN's Avatar
Quoted: 15 Post(s)
Originally Posted by Dfelt75 View Post
UPDATE TO MY UPDATE
Have you tried to do a Valve Spray cleaning and run some fuel system cleaner as well to rule out dirty fuel system or dirty intake valves?
SAAN is offline
post #14 of (permalink) Old 1 Week Ago Thread Starter
Dfelt75's Avatar
SAAN you were correct.
Just did a coolant flush and also picked up some crc gdi cleaner...half through throttle body and other through brake booster line.
The shudder is gone.
Long live my 3.6
Dfelt75 is offline
