2013 Impala LT Tranny Issue - Chevy Impala Forums
  • 1 Post By MarkTN
post #1 of (permalink) Old 02-12-2019 Thread Starter
MarkTN's Avatar
Quoted: 18 Post(s)
This problem has been going on for quite a few miles now but of course I never noticed it until after the powertrain warranty expired. When the transmission is in over drive and begins to encounter an area where it will have to pull harder I can feel a vibration in the steering wheel and can sometimes hear a growling sound as well. As soon as it downshifts both stop. There is no slipping or any other problems with it other than this but I am afraid it is just the beginning of something more involved. The car has about 130,000 miles on it and I have drained and refilled the tranny fluid about every 30,000 miles. Any helpful input on what might be the cause or cure would be greatly appreciated. Thanks.
MarkTN is offline
post #2 of (permalink) Old 02-12-2019
Quoted: 255 Post(s)
I have noticed over several vehicles now a vibration occurs when the motor is lugging itself in too high of a gear. these cars are programmed for economy so they try to hold as high of a gear as possible (like staying in 6th gear on your car) to keep the rpms down so you get better mileage. when you feel the vibration, see where the rpms are at. are they down around 1k rpm or something low like that? what happens if you take your foot off the gas or downshift it a gear. i suspect you're just noticing the motor "lugging itself" because it isn't downshifting in favor of better mileage. when the motor lugs it can create a vibration as it is straining to maintain that rpm, being that your motor is attached to the trans which has the axle shafts going into it, you would more than likely feel the vibration in the steering wheel.
on my 2010 i could duplicate this issue every time on the same exact hill (the 4 speed trans would shift into overdrive right at the bottom of the hill then it wouldn't shift unless i gave a sudden pedal change of more or less throttle).
heck, my v8 silverado does this frequently, you can feel the steering wheel shaking moderately. downshift it or take your foot off the gas for a second then reapply the throttle and it goes away for short period.
Joes74challenger is offline
The Following 2 Users Say Thank You to Joes74challenger For This Useful Post:
MarkTN (02-13-2019)
post #3 of (permalink) Old 02-15-2019 Thread Starter
MarkTN's Avatar
Quoted: 18 Post(s)
My symptoms do occur around 1k RPM's so I'm inclined to agree with what you said in your post. But it doesn't make it any less annoying to me. lol. Thanks again.
Joes74challenger likes this.
MarkTN is offline
post #4 of (permalink) Old 02-15-2019
Quoted: 932 Post(s)
Also - your car didn't always do that, so it shouldn't be doing it now. The trans programming hasn't changed, so why is it doing this all of the sudden now? I don't believe that "it's just the way it is" - there is something wrong.
I wonder if resetting the trans adaptives would make any difference - even if temporary... If it were my car, I think I'd try disconnecting the battery overngiht and see how that affects things - if nothing else, it may help with troubleshooting the issue. It costs nothing and is easy to do.
jtrosky is online now
post #5 of (permalink) Old 03-06-2019
SAAN's Avatar
Quoted: 17 Post(s)
I have the same mileage as you on my 2012 LTZ and the symptom start occurring more around 90K and got a tad worse after the dealer did a transmission fluid flush. I recently did a Direction injection Spray cleaning with CRC Intake cleaner w/PEA and then ran some Gum Out Fuel System cleaner w/ PEA and the shuddering has pretty much went away by atleast half. So you can try running some fuel system cleaner like I did as well and see if it helps.
SAAN is offline
The Following 2 Users Say Thank You to SAAN For This Useful Post:
MarkTN (03-07-2019)
2013 impala Lt tire pressure sensors xtremewhite99 Chevy Impala 8th Gen Discussion 28 07-18-2019 04:10 PM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 05-18-2018 10:10 AM
Engine Air Filter 2012 2013 CHEVY IMPALA LS LT LTZ 2014 2015 2016 IMPALA LIMITED RSS Bot Impala Diecast Toys Cars on eBay 0 05-03-2018 02:50 PM
Impala ss rims for my 2013 LT xtremewhite99 Chevy Impala 8th Gen Discussion 0 04-17-2018 08:57 PM
