Clicking Noise when Turning Right - Chevy Impala Forums
7th Gen Suspension Springs, shocks, and brakes.
post #1 of (permalink) Old 07-11-2010 Thread Starter
BUCKEYE's Avatar
Clicking noise while turning right
I've had this hollow clicking noise, like metal and plastic hitting, when I turn right or backing up turning left. I've replaced both cv axles and wheel hub assys. Still have the same noise. Jacked the car up, put it in gear turned right and no noise. The noise only appears as the wheel is turning under load- I guess. If I hold the steering wheel steady in the turn it still makes this hollow clicking noise so I didn't think it was steering column related. My brake shop said it might be a cracked torque converter flex plate. Never heard of that. It's a 2004 3.8.
BUCKEYE is offline
post #2 of (permalink) Old 07-12-2010
Moderator
wanderson75's Avatar
Are you using stock size rims and tires? And have you checked for wear on the insides?
–adjective
wanderson75 is offline
post #3 of (permalink) Old 07-12-2010
impala05's Avatar
check your internal steering shaft, you might have to get it greased or replaced.
impala05 is offline
post #4 of (permalink) Old 07-12-2010
idrivejunk's Avatar
Cracked flexplates are common (and dangerous) in RWD vehicles (mostly what I know about), and make all sorts of death noises. I wouldn't rule that out. Definitely check all around the tire. Wheel center or lugnut covers, wheel weight or CV boot clamp hitting something, that type of thing. I suppose it could be a differential problem, too, but that costs a trans rebuild to find out.
idrivejunk is offline
post #5 of (permalink) Old 07-13-2010
Moderator
Cracking flexplates are seriously rare in our cars and usually only happen to those that are running some monster horsepower.
I'd be more inclined to think that it's either the sway bar torquing due to bad bushings, or it's also possible that the engine cradle bolts are loose, which is a common occurence in our cars.
–adjective
post #6 of (permalink) Old 07-13-2010
idrivejunk's Avatar
All good to know. I am new to the FWD game. My first is a 99 GP GT and I've only had it about a year. Learning as I go. Glad to know the flexplates don't cause much trouble. Sway bar bushing sure could make that noise.
post #7 of (permalink) Old 07-13-2010
Moderator
Top swap that baby!
–adjective
post #8 of (permalink) Old 09-12-2018
Bucky316's Avatar
Originally Posted by buckeye View Post
i've had this hollow clicking noise, like metal and plastic hitting, when i turn right or backing up turning left. I've replaced both cv axles and wheel hub assys. Still have the same noise. Jacked the car up, put it in gear turned right and no noise. The noise only appears as the wheel is turning under load- i guess. If i hold the steering wheel steady in the turn it still makes this hollow clicking noise so i didn't think it was steering column related. My brake shop said it might be a cracked torque converter flex plate. Never heard of that. It's a 2004 3.8.
my impala is making the exact same noise,id love to know what you found out
Bucky316 is offline
post #9 of (permalink) Old 11-03-2018
KCGMfan's Avatar
have you checked the starter? I had a Buick LeSabre with the 3.8 that would make a noise while turning right and it turned out to be the return spring in the starter was broke letting the starter gear rub the flexplate
KCGMfan is offline
another clicking noise under the dash carls car issues Autocare and Maintenance 3 01-12-2019 08:30 AM
Loud clicking noise after using key fob Cybertech Audio, Video, and Electronics 3 10-19-2018 06:41 AM
Dreaded Clicking Noise Dave_N Chevy Impala 8th Gen Discussion 5 07-28-2018 12:14 PM
2017 premier impala - high frequency squeaking noise when turning car off 37865835235 Chevy Impala 9th Gen Discussion 5 07-20-2018 08:02 PM
2010 Chevy Impala LT/Loud clicking noise Jimarie Chevy Impala 8th Gen Discussion 1 07-16-2017 02:07 PM
