1965 Impala Budget Disc Brake Conversion - Page 4 - Chevy Impala Forums
1st - 5th Gen Suspension Springs, shocks, and brakes.
 3Likes
post #46 of (permalink) Old 12-01-2014
Rebelrouser's Avatar
The reason I used 2 RH is because it was what I had to work with at the time and I was trying to duplicate what GM did on the Camaro in '69 and I wanted a fully functional 4 corner 4 piston caliper brake set up. The process was real easy once I figured out all the mounting brackets and how everything works. It all depends on what look you are trying to achieve- OEM '68 and older brakes that look dealer installed or any generic brake kit that everyone does. I did it to be different and yes they got noticed.
I do have a freshly rebuilt JL-8 clone 12 bolt sitting here-for sale- that I used as a template for my rear disc brake installation on my '66 "B" body. Keep in mind that in order for this set up to work it has to be installed on a "B" body 10/12 bolt. That's how GM did it in '69- they used the "B" body axle tubes and pressed them into the "F" body 12 bolts to accommodate the C3 rear brakes. I have done extensive research so that this does work. The stopping power will really surprise you. And like I said, everything is available over the counter for '65-'82 'Vette.
If you have any questions-pm me....
Cheers,
Rebelrouser is offline
The Following 2 Users Say Thank You to Rebelrouser For This Useful Post:
Sam Axe (07-29-2019), VonMises (12-02-2014)
post #47 of (permalink) Old 04-26-2015
Cowansauto's Avatar
Originally Posted by jmink427 View Post
Here are some pictures of the conversion I made for my 1965.....My car had drums all the way around...... I used front Calipers and rotors from a 2000 Z28 and on the back disc I used 2000 Olds Brivada calipers and rotors for a '1992 Z28.. I had to make all the brackets and such. It took me some time and a lot of measuring, but they work great, and use all GM parts.... Sorry I didn't have more pics of the rear brakes.... My car has a 9" ford rear end in it and the caliper brackets I made also double as the bearing retaining plates...
Just to clarify, you used factory drum brake spindles?
Anyone seen anybody adapt the 4th gen Camro brake calipers to stock Impala disc brake spindles? I have a pair of these calipers and would like to use them on my 1970 build.
Cowansauto is offline
post #48 of (permalink) Old 04-26-2015
MonzaRacer's Avatar
4th Gen calipers are very weak and flex a lot.
The preferable caliper same as Fbody, are C5-C6 calipers, and if you buy rebuilt ones just drop Fbody ones in box for cores.
But for the 65-70 B body my professional opinion is use the 68-82 Corvette parts (C3) as the rebuilder parts are solid parts if obtained from reputable rebuilders.
Or you could buy Vette spindles, and one of the upgrade C3 Corvette brakes from aftermarket.
Reason to NOT use the Bcar parts from 67-70 is the lack of replacement parts over more preferable and available Corvette parts.
MonzaRacer is offline
post #49 of (permalink) Old 05-04-2015
jmink427's Avatar
Quoted: 4 Post(s)
yes sir, drum spindles and hubs
https://www.impalaforums.com/signaturepics/sigpic22500_2.gif
jmink427 is offline
post #50 of (permalink) Old 05-10-2017
bjornas's Avatar
65 Disc Brakes
Hi!
Did you CNC cut your brackets?
bjornas is offline
post #51 of (permalink) Old 05-10-2017
jmink427's Avatar
Quoted: 4 Post(s)
Originally Posted by bjornas View Post
Hi!
No sir, I didn't have that luxury. I just scribed them out and used a band saw and a manual vertical mill to cut the reliefs.
Sent from my XT1585 using Tapatalk
jmink427 is offline
post #52 of (permalink) Old 05-10-2017
bjornas's Avatar
Nice job!!
Did you keep your template?
I would like to ask for a copy if you have?
Bjorn
bjornas is offline
post #53 of (permalink) Old 05-11-2017
jmink427's Avatar
Quoted: 4 Post(s)
Nice job!!
Bjorn
I don't have one for the front brakes, but I do for the back, unfortunately it's for a big bearing end Ford 9" because that's what I put under my Impala.
jmink427 is offline
post #54 of (permalink) Old 07-25-2019
Sam Axe's Avatar
Cheers,
Finally got around to doing my 65. I've held onto this thread for some time.
I have the front spindles and hubs. When Moser built my Diff, I mentioned that I was planning on C3 brakes. They said that was good to know, because they made the axles to fit the brake.
Sam Axe is offline
LinkBack to this Thread: https://www.impalaforums.com/1st-5th-gen-suspension/300270-1965-impala-budget-disc-brake-conversion.html
brake conversion 65 impala - ChevyTalk - FREE Restoration and Repair Help for your Chevrolet This thread Refback 03-19-2018 10:07 AM
Any tips or links to GM A Body 4 wheel disc brake conversion? This thread Refback 11-02-2014 07:33 PM
NOS CHEVY IMPALA 1958 - 1964 1965 - 1970 CHEVROLET Rear + Front BRAKE HOSE Set RSS Bot Impala Diecast Toys Cars on eBay 0 08-06-2017 02:10 PM
1991-1996 CAPRICE POLICE IMPALA SS SPINDLE KNUCKLE PAIR for S10 Brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 08-06-2017 02:10 PM
1958-1964 chevrolet impala belair 2 inch drop spindles for disc brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 08-01-2017 05:00 PM
1965 1966 1967 1970 chevy impala complete 8" dual chrome power brake booster kit RSS Bot Impala Diecast Toys Cars on eBay 0 07-27-2017 09:00 AM
1991-1996 CAPRICE POLICE IMPALA SS SPINDLE KNUCKLE PAIR for S10 Brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 07-23-2017 03:40 PM
