Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > General Discussion > Wheels and Tires
Old 04-25-2008, 07:17 PM   #1 (permalink)
uncle jerry
uncle jerry's Avatar
Converting a 2008 impala SS into a rear wheel drive?
how much would it cost and how hard do you think it would be?
Sponsored links
Old 04-25-2008, 07:17 PM   #2 (permalink)
nyninchdick
nyninchdick's Avatar
It would cost more than buying a high performance rear wheel drive car, it would give you all kinds of grief for insurance, licensing, etc, it would void your entire warranty, give you all kinds of handling problems, etc. Should I go on? If you're thinking that NASCAR does this, they really don't. Those cars are built on a custom fabricated frame, with a fiberglass replica of a (Monte Carlo, Impala, Charger, etc.) body fitted to it.
Old 04-25-2008, 07:17 PM   #3 (permalink)
Jeff S
Jeff S's Avatar
Your crazy!
Old 04-25-2008, 07:17 PM   #4 (permalink)
John m
John m's Avatar
wow thats gonna cost some money. and i assume that you are still paying for it so thats even more money. you need an axle, new suspension, engine mounts make the tunnel for the exhaust bigger cause you need a tranny and driveshaft in there. new computer all sorts of crap. good luck if you do it. hope you have the time and what it takes.
Old 04-25-2008, 07:17 PM   #5 (permalink)
daewoolagunza
daewoolagunza's Avatar
7200 hundred dollers u have to take out the engine get and engine from cheverolet thats capable of fitting in the car and changing some front suspention and rear supenion componentes labor about 5600 dollers good luck and a bad idea i would say doesnt make no sence to me
Old 04-25-2008, 07:17 PM   #6 (permalink)
sixoneurdun
sixoneurdun's Avatar
more than it's worth
because the under body nor the rear end is designed for that.
you'd be better off taking the frame off and putting it on a rear wheel drive car.
the engine could be modified fairly easily but running the drive shaft and the transmission would be costly.
Old 04-25-2008, 07:49 PM   #7 (permalink)
350 INCH 95's Avatar
You'd probably just be better off buying a Pontiac G8 GT. It's sold as a Chevy Caprice in Saudi Arabia, which is basically an Impala.
95 DGGM WX3
Cam'd, Port'd, Header'd, Rim'd, Lower'd, Diddy Kong in the trunk
350 INCH 95 is offline
Old 04-25-2008, 08:13 PM   #8 (permalink)
moneypit
moneypit's Avatar
even if you did convert it, you would have to put a heck of a lot of thought into engineering the suspension and placement of components in order to make it handle correctly which would take you a long time to get dialed in. i agree with the G8 GT. i dig that car.
Old 04-25-2008, 08:19 PM   #9 (permalink)
77Impala's Avatar
It's just not worth it. If you want a rear drive car then buy a rear drive car. I do like my rear drive Impala that I have. I have not yet driven the FWD Impala's.
1977 Impala Sedan, 5.0L, TH200, 3.25:1, 79K miles, 26 Lifetime Warranty Parts.
1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 348K miles, 9 Lifetime Warranty Parts.
77Impala is offline
Old 04-25-2008, 09:56 PM   #10 (permalink)
moneypit
moneypit's Avatar
i have and they don't hook up. IMO, that has always been the problem with front wheel drive cars. the weight distribution when they lauch kills all of the traction.
vB code is On
What is the most reliable, comfortable and fun to drive? A 2008 Altima 3.5SE,... WALLY Chevy Impala Discussion 6 02-04-2010 02:45 PM
will the chevrolet impala change to rear wheel drive (zeta platform) for 2010 model? Tom M 2011 Chevy Impala / Caprice Discussion 1 02-12-2008 10:05 AM
how do you remove the rear skirts from a 1993 Cadillac Fleetwood rear wheel drive? pressman5069 Buick Roadmaster 1 11-05-2007 01:39 PM
My 1998 chevy blazer is stuck in four wheel drive how do I fix this? amygrtn Automotive Discussion 0 09-05-2007 02:26 PM
Where can i find a cheap actuator for my 4 wheel drive on a 91 chevy 1500 w/t? thehatch2002 Automotive Discussion 1 09-02-2007 10:03 PM
Sitemap Index - Archive
