| Home | Garage | Register | FAQ | Members List | Link To Us | Shoutbox | Active Topics | Mark Forums Read |
hub bearing - rubbing noise @ 35mph
my son has a 2004 Impala LS and runs nice...
Recently started having this... If you barely turn the wheel left, you hear a "rubbing noise" at about 35-40mph. If straight, or barely turning right - no noise. Took it to the local dealer, and they said it is the right front hub bearing, with a cost of $513 to replace.... the sealed hub is $283, and 1.6hrs labor is $192, and then taxes, shop fee BS = $513 SO - I can't remember if I've ever had a bearing replaced ??? Anything special cause this to happen... our recent Chicago potholes, icy weather, what ? Last edited by ps56k : 03-06-2008 at 06:56 PM. |
| Sponsored links | ||
i just bought a hub for less than $100, installing myself for free. these bearings just wear out sometimes and the potholes certainly dont help the matter. if you want to make sure its the hub, just jack the car up, grab it from the top and bottom, like the 12 and 6 position, and see if you have any movement. if so, then yes your hub is bad. while its up, try to shake it left and right, if you get movement thats usually a sign of tie rods.
#3 (permalink) |
BEWARE OF AFTERMARKET HUB BEARINGS!! I had 2 different cars come back after I installed aftermarket hub bearings, due to play. And they only drove 5,000 miles on the aftermarket bearings. The dealer part may be expensive, but usually they're pretty good, I haven't had one come back yet.
#4 (permalink) | |
94 BBB Clone - when it grows up, it's going to be a racecar. 08 F-350 Super Duty 4x4 6.4 Diesel (26MPG) Ford Diesel Certified Technician |
| Rubbing Rims | 73impala | Wheels and Tires | 2 | 01-02-2009 02:02 PM |
| I keep breaking the carrier bearing | BigRedSleeper | 1st - 5th Gen Drivetrain | 12 | 10-20-2008 10:54 AM |
| what BRAND wheel bearing should I get for my 2001 grand prix gt? | american_bulldog25 | General Automotive Discussion | 0 | 09-07-2007 07:52 AM |
| I am in the end of taking my front bearing off of my 2000 GMC Jimmy. What... | rads92 | General Automotive Discussion | 0 | 09-06-2007 03:14 AM |
| Does any one know how to repair the wheel bearing on a 2001 Chevy Impala? | ludicontreras | Mechanical and Electrical Problems | 0 | 09-02-2007 10:03 PM |
