| Wheels and Tires All about wheels and tires. |
Tire Pressure Monitoring System on 2010 LTZ
I previously had a 2006 LTZ and it required me to learn the new wheel positions when I rotated the tires. I don't see a learn feature on my 2010. Does anyone know if this is no longer required? Did GM finally make this automatic? Thanks for any input.
| Sponsored Links | |||
Advertisement | |||
I finally found it! On my 06 you use the DIC to go into the learning mode and on a 2010 its the parking break and FOB. You have got to be kidding me!!!!! How stupid!!!!! Why change a process that worked fine and made sense!!!!!!!
#3 (permalink) |
SStuntin on em
![]() ![]() Join Date: Jan 2011
I was gonna say the dic, but what is it for 10+? Parking break and fob? Idk I rotated mine, and I've learned the positions multiple times, but it still thinks my rears are in the front, and vice versa...
__________________ ![]() |
#4 (permalink) |
![]() Join Date: Jan 2012
Turn the key to the run position and press and hold the key fob buttons "lock" and "unlock" at the same time.
It will go into learn mode I bought one of these and it takes about 1 minute to do GM Special Service Tools |
#5 (permalink) |
parking break set, key in run position but not started and press lock/unlock on the fob at the same time for 5 sec The horn will chirp letting you know your in the learning mode. Start with the left front tire either letting air out or adding for 5 seconds or so. Then the horn will chirp and then move clockwise. After the left rear the horn chirps twice turn off the key and your done.
| Sponsored Links | |
Advertisement | |
LinkBack to this Thread: http://www.impalaforums.com/wheels-and-tires/319532-tire-pressure-monitoring-system-on-2010-ltz.html
| Tire Pressure Monitoring System on 2010 LTZ - Chevy Impala Forums : 2011 Impala Forum | This thread | Refback | 04-09-2012 03:43 AM | |
| tire pressure | rod1416 | Wheels and Tires | 7 | 02-08-2011 01:04 PM |
| Tire pressure monitor system, 2007 SS | plano-doug | Wheels and Tires | 3 | 08-01-2010 09:30 AM |
| Tire pressure monitoring system problem | 4spd409 | Automotive Discussion | 4 | 03-30-2010 11:00 AM |
| Low Tire Pressure | darkbandit88 | Autocare and Maintenance | 3 | 02-06-2009 07:30 PM |
| 08 Impala Tire pressure system... | andrewjs18 | Chevy Impala Discussion | 2 | 11-18-2008 05:44 PM |
