Homemade Wide White Walls - Chevy Impala Forums
post #1 of (permalink) Old 08-06-2009, 10:48 PM Thread Starter
klattu's Avatar
A 5 minute video of my Roadmaster wagon getting the white walls widened.
Before and after.
I'm not sure which one of these will work
klattu is offline
post #2 of (permalink) Old 08-07-2009, 02:06 PM Thread Starter
klattu's Avatar
Eye Sea
Yes,
Very good idea for all automotive work to have safety glasses.
Suffered many days thru the years from exhaust pipe rust falling into eyes.
Many items I could add too...
Don't engauge the parking/emergency brake
Do this outside only
Double jacks and stands for extra safety
Be cautious of courious neighbors, they will gather quickly to see WTF you are doing to your tires.
Tips:
I rock the polisher (not grinder as I speak in video) in a curve motion.
This scrubs off the letters and imperfections in the area.
As I am removing rubber, I am looking for the outer limits of the white to begin to show thru.
Don't stay in one spot too long, keep rocking.
Once the outside edge of white is found, I begin to lower everything between the inside edge and the outside edge.
BFGoodrich has the widest I have found.
These are Bridgestones in video.
This is a well worn 40 grit that I used, slower than new, but much smoother results.
I did not need to polish after with a 3M pad...so maybe if your starting new, use a 80 grit.
His and Hers 1996 Buick Roadmaster Wagons
N.S.R.A. Lifetime member
klattu is offline
post #3 of (permalink) Old 08-07-2009, 02:50 PM
77Impala's Avatar
Quoted: 6 Post(s)
I just want to add for those whom decide to do this to be very careful and follow all of the above safety information.
Also remember that you are removing some of the rubber from the side wall of the tire. In some rare cases that may weaken the outer wall of the tire and make the tire dangerous of a blow out.
I will say that I do like the wider white walls myself.
Nice job Klattu.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #4 of (permalink) Old 08-07-2009, 03:58 PM Thread Starter
klattu's Avatar
Thanks,
If you ever get the chance to cut a tire across the white wall, you will see less than 1/16" (1.5mm) of black on top of the white wall.
I discovered this making some crane protectors from old tires.
Of course anything is possible, but in the 28+ tires done so far, zero sidewall problems.
The heaviest, or most tire under a strain that I have done would probably be the 75 Eldorado, FWD with a 500 sitting on top.
Many trips to Florida during the hot summer and still looks good.
klattu is offline
post #5 of (permalink) Old 08-07-2009, 04:33 PM
COLD STEEL's Avatar
Originally Posted by klattu View Post
Thanks,
You did a good job and thanks for the how to video.....its good to see people sharing tips and techniques.
COLD STEEL is offline
post #6 of (permalink) Old 12-09-2009, 04:42 PM
bayareaXimpalaX95's Avatar
Awesome video!!! thank you for being kind enough to want to share that technique with the all of us.
bayareaXimpalaX95 is offline
post #7 of (permalink) Old 03-27-2010, 08:13 PM
iceship's Avatar
white wall paint
has any one used that white wall paint.......
Wagon lover forever
iceship is offline
post #8 of (permalink) Old 01-23-2014, 05:37 PM
702•LTZ's Avatar
Old thread i know. But my friend wants to know about doing white walls. Does it require an already white wall tire or white letter tire? Or can any tire have this conditioning
<a href=http://s1281.photobucket.com/user/702ltz/media/Mobile%20Uploads/20150112_165711_zpsah6xjvc_edit_1421167783579_zpsvuvufe2j.jpg.html target=_blank><img src=http://i1281.photobucket.com/albums/a518/702ltz/Mobile%20Uploads/20150112_165711_zpsah6xjvc_edit_1421167783579_zpsvuvufe2j.jpg border=0 alt= /></a>[/URL]
"I didn't really set a timeline for it to be done. I just wanted to make sure that when it was finally completed, it would meet my expectations."
702•LTZ is offline
post #9 of (permalink) Old 01-23-2014, 06:36 PM
Quoted: 51 Post(s)
It requires a white letter/white wall tire to start.
*2001 Impala Ls - 129k
*2000 Blazer 4x4 - 174k
Winter daily
*1977 C10 - Work in progress
*2014 Impala LT Limited - 35k
RYD SLO is offline
post #10 of (permalink) Old 01-23-2014, 06:42 PM
702•LTZ's Avatar
Ok. That's what I thought, after reading many a rat-rod forum. Thanks for confirmation.
702•LTZ is offline
post #11 of (permalink) Old 06-20-2014, 04:20 PM
tomthebomb's Avatar
I bought white wall paint off line, looked awesome!... For 2 weeks lol, chipped, cracked, browned, flipped my tires.
00 LS 3.8L, 200k mile club, HID's, led tail light assemblies, led tag lights led interior lights, 2 inch drop, 20% tint, black roof vinyl, ss spoiler, and so on and so forth...
tomthebomb is offline
Where's the White? Tommy K Off-Topic Discussion 79 11-05-2008 12:36 PM
I have a White 2008 Chevy Impala that I want to paint Black, does any idaim_robles Appearance 2 05-10-2008 08:07 PM
I would paint this thing black and white and have some fun Richard Chevy Impala Discussion 3 04-18-2008 09:39 AM
Will the Impala SS be used in the Nascar Nation Wide Series Next year? joshrb10 Chevy Impala Discussion 2 12-01-2007 04:05 PM
Diesel truck blowing white smoke? Lisa Automotive Discussion 2 09-08-2007 05:13 AM
