| Restoration Forum Topic related to restoration of classic Chevy Impalas. |
distributor replacement for 283
rebuilding my 283. Anyone have any opinions about replacing my original distributor with a new hei distributor. I've seen them for as little as $40 + shipping and my old distributor needs some work. The motor is being rebuilt throughout. Any feedback on these hei distributors?
| Sponsored Links | |||
Advertisement | |||
I highly recommend you do it. With an HEI distributor you never have to worry about points again and you'll do away with the external coil. Kinda funny you posted this, I just finished putting together a friend's 1951 Ford pickup last night with a 283 Chevy in it... he insisted I put the points ignition back in it. An HEI is so much more dependable & clean looking, and all it takes is to connect your positive & negative wires from the old coil to the positive & negative prongs on the HEI, drop it in, change the plug wires, set the timing, and you're ready for years of hassle-free ignition.
#4 (permalink) |
Well, in most cases you get what you pay for. Watch the $40 HEI distributors, they can nickel & dime you to death IF they don't come with everything you need such as the coil (mounts in the center of the cap), the rotor, cap, and ignition module. I'd buy one already set up to drop in & run. They have really came down in price, I need to buy one too for my '64 so i'll look around soon & give you some recommendations. Keep in mind the HEI distributors are bigger around than a points distributor, but unless you've wedged a 350 into a model A coupe clearance isn't a problem between the distributor & firewall.
#5 (permalink) |
Go to a pick your part wrecker. I find them there for $5.00. Usually I grab another just to have a spare one. I got rid of the points in my 62 Biscayne, best thing I did. I can't even remember how to set points any more.
__________________ 1962 Biscayne 18's +20's-Coys,disks all around,power steering,Ididit column lowered and having fun |
#6 (permalink) |
Depending on your car you may want to look at some of the more compact HEIs. The older models didn't fit my son's 55 chevy. Clearance issues with the firewall.
He initially bought one of those conversion kits. Wasn't worth it! |
| Sponsored Links | |
Advertisement | |
| which distributor | 94ssblk | Chevy Impala 6th Gen Discussion | 1 | 05-29-2010 10:09 PM |
| 96 Caprice LT1 350 Distributor ??? | Bubby S | Chevy Caprice | 6 | 02-02-2010 10:37 PM |
| HEI distributor for my carbed lt1? | heybobo! | Automotive Discussion | 2 | 09-02-2008 12:56 AM |
| What causes moisture build-up in a LT1 distributor? | Rich | Automotive Discussion | 4 | 08-19-2008 08:37 AM |
| i think my distributor is a tooth off!? | bbsr72 | Automotive Discussion | 1 | 09-06-2007 12:29 AM |
