1970 Fuel sending unit replacement - Chevy Impala Forums
Restoration Forum Topic related to restoration of classic Chevy Impalas.
post #1 of (permalink) Old 08-09-2010, 04:21 PM Thread Starter
alanator's Avatar
The fuel guage didn't work on my 70 impala so I decided to replace the sending unit in the fuel tank. The original unit is a canister design with two lines. One line is the supply and the other is the return. The only replacement I could find was a 1 line unit. The problem is what to do with the return line? Right now I have Tee'd it in to the vapor line close to the tank. The only thing I can think of is to remove the sending unit, drill a hole in top and install a fitting with tubing.
I don't remember seeing a fuel system design like this. In front of the engine is a metal filter looking thing which has 1 line coming in from the pump. 1 line goes to the carb filter housing and 1 small line goes back to the tank (return). It has a Quadrojet carb 4MV. What is the purpose of the return line? Any help guys? Thanks
alanator is offline
post #2 of (permalink) Old 08-10-2010, 11:43 AM
77Impala's Avatar
Quoted: 6 Post(s)
I would pull the sending unit back out and drill into either the tank or sending unit if there is enough room and install the new return fitting. I would prefer the tank so that the sending unit sensor is not damaged from the drill motor's vibration.
77Impala is offline
post #3 of (permalink) Old 08-16-2010, 09:02 PM
velvet muldoon's Avatar
to got off subject whats the deal with my 70 not deviating from half tank? even when empty or full? rust on the sending unit? remove and see?
velvet muldoon is offline
post #4 of (permalink) Old 08-16-2010, 09:10 PM
77Impala's Avatar
Quoted: 6 Post(s)
Originally Posted by velvet muldoon View Post
to got off subject
1.whats the deal with my 70 not deviating from half tank? even when empty or full?
2. rust on the sending unit?
3. remove and see?
1. Don't know for sure.
2. Possible, especially if the car has sat for a long while.
3. Yes that is the best thing to do. Also replace the rubber fuel lines from the tank to the steel lines.
77Impala is offline
1970 Impala Fuel tank sending unit klard Impala 1st - 5th Gen Discussion 7 05-26-2015 10:40 AM
6th gen fuel pump sending unit ???? POPIMPIN CUSTOMS I.N.C 6th Gen Engine Performance 5 03-12-2010 05:37 PM
fuel tank sending unit may be in my future ssety Automotive Discussion 7 11-27-2009 07:57 PM
Fuel sending unit ibm9902003 Chevy Caprice 0 08-08-2008 03:25 PM
Help: 96 RM Fuel sending unit needed uaart1 Wagon Discussion 3 07-17-2008 09:24 AM
