ecu reset - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > PCM and Technical Tuning
Old 09-20-2012, 03:50 PM   #1 (permalink)
countryrunner's Avatar
ecu reset
hey guys i just did some mods to the stock intake and i need to reset the ecu so the computer can re-learn with the new mods. i tried to disconnecting the battery for 15min and that did not work because the radio presets where still there. any suggestions?
countryrunner is offline   Reply With Quote
Old 09-20-2012, 04:42 PM   #2 (permalink)
463
463's Avatar
When you pull the battery cables tape them together with the + to the -. Then turn the key to the run and turn on light switch. This pulls all the stored power out. So after 15 to 60 min turn off all the switches and reconect your cables. Then you have the computer reset.
Welcome to the forum
463 is offline   Reply With Quote
PCM/ECU Reset Fearthedeerss Chevy Impala 6th Gen Discussion 11 09-30-2011 06:28 AM
how do i reset the ECM on my 91 caprice HeavyChevy Chevy Caprice 4 03-29-2011 09:28 PM
how do I reset the cd player on my 2003 impala? becky.gann Chevy Impala Discussion 2 04-13-2008 12:19 PM
How do you reset the clock on a chevrolet silverado? queenareida Automotive Discussion 0 09-07-2007 11:40 PM
Does anyone know if you have to reset the computer or such after swapping 6cstevec Automotive Discussion 0 09-05-2007 03:30 AM
