garage says catalytic converter is gone. no check engine lights are on. but... - Chevy Impala Forums
N2O, Methanol, Water, and Alcohol Injection N2O, Methanol, Water and Alcohol injection.
post #1 of (permalink) Old 03-10-2008, 10:10 AM
saucyj123
saucyj123's Avatar
Quoted: Post(s)
...car has no power.its 2003 impala? chev impala 2003 ls
post #2 of (permalink) Old 03-10-2008, 10:30 AM
brandonlahman
brandonlahman's Avatar
Quoted: Post(s)
I am not sure what your question is, but if it is along the lines of you not believing the shop your car is at do this.
Crawl underneath it and if your converter is gone you will notice it immediately. Look at where your exhaust pipe leaves your engine and follow it to the back of your car. I should be one solild piece with the converter about half way to the tail pipe.
No power in your car leads me to believe your converter is hosed up.
post #3 of (permalink) Old 04-20-2008, 05:13 PM
moneypit
moneypit's Avatar
Quoted: Post(s)
have you noticed any weird smells? is the cc getting hotter than usual?
post #4 of (permalink) Old 04-27-2008, 08:42 AM
Moose's Avatar
Since this is in the nitrous section, if you are spraying the car pretty heavily, the cat has likely melted and is effectively acting like the bananas that Eddie Murphy used in that old LTD in the original Beverly Hills Cop movie.
Unbolt the downpipe from the manifold, and take it for a drive and see if the power returns. Failing that, you can do an exhaust backpressure test or watch the engine vaccuum to determine weather or not the exhaust is restricted.
94 BBB Clone - when it grows up, it's going to be a racecar.
08 F-350 Super Duty 4x4 6.4 Diesel (26MPG)
Ford Diesel Certified Technician
Moose is offline
post #5 of (permalink) Old 04-30-2014, 09:18 AM
fordolet's Avatar
HI, Our 2001 3.4 Impala once hardly made it home up some hills. The Catalytic converter was plugged. It would idle ok. We had some time previously gotten a letter from GM telling about a possible problem with the converter. The Chevrolet dealer ended up replacing it for free.
fordolet is offline
post #6 of (permalink) Old 04-30-2014, 09:35 AM
auntjemima's Avatar
6 year bump. That has to be some sort of record.
auntjemima is offline
The Following User Says Thank You to auntjemima For This Useful Post:
CinRed (04-30-2014)
Catalytic converter? JamesM Automotive Discussion 7 11-07-2008 08:59 AM
problem with 83 chevy caprice (catalytic converter maybe) Bryan W Chevy Caprice 0 08-06-2008 06:20 PM
2001 Chevy Impala Catalytic Converter? Maurcus D Chevy Impala Discussion 2 10-28-2007 06:39 AM
catalytic converter 03 Impala? br0hamus Mechanical and Electrical Problems 0 10-04-2007 05:15 AM
99 Grand Am 75000 miles-catalytic converter test? aznightwolf Automotive Discussion 0 09-12-2007 03:28 PM
