Before Nitrous? - Chevy Impala Forums
N2O, Methanol, Water, and Alcohol Injection N2O, Methanol, Water and Alcohol injection.
post #1 of (permalink) Old 01-23-2009, 08:02 AM Thread Starter
01 Blackout's Avatar
Send a message via AIM to 01 Blackout
Before Nitrous?
Besides a reinforced intake manifold, and possibly fuel injectors, what else would I need to make sure my motor wouldn't blow and also make sure I get the most power.
01 Blackout is offline
post #2 of (permalink) Old 01-23-2009, 06:25 PM
Moderator
04DetroitLS's Avatar
wet kit and a tune
04DetroitLS is offline
post #3 of (permalink) Old 03-30-2009, 09:25 PM
cbtlr's Avatar
Make sure your timing is retarded for nos and run a high octane fuel to prevent ping.What mods were done to engine if any and how much nos do you plan to spray?
cbtlr is offline
post #4 of (permalink) Old 03-31-2009, 06:08 AM
Moderator
the tune should take care of the timing issue for him, if he goes wet kit, spray after the MAF (tb spacer) if dry, spray before
the reinforced manifold isnt an issue, if youre that worried about it, find a L26 UIM
post #5 of (permalink) Old 04-21-2009, 09:11 AM Thread Starter
RE
I have slp headers, reinforced intake mani, high flow cat, tps enhancer, k&n intake. i wanted to run the ZEX WOT kit
-F1NAL G3AR- [Get Used To It]
post #6 of (permalink) Old 04-21-2009, 10:24 AM
Quoted: 18 Post(s)
reinforced intake only survives a BAD mistake. What you should really aim for is to avoid the mistake.
Make sure the fuel system is up to the task, depending on the hit a stock pump might be fine IF it is in good condition, if it is original and 8 years old then it might not be up to the task.
Wet kits do not need injector upgrades and if you upgrade injectors for a dry kit you have to retune for them.
Personally I think an aftermarket ignition box like the Mallory is important for nitrous use. Gives a spark based rev limiter most stock ones are fuel based and would be instant death for the engine on nitrous. They have a window switch so you can shut off the nitrous during the shift saving the tranny, and you can have it pull timing instead of losing NA power due to a low timing nitrous tune.
Going to want to put in colder NON PLATIMUN plugs too. Cheap plugs are fine for nitrous, actually prefered over platinum or iridium.
Dwayne J is offline
post #7 of (permalink) Old 04-29-2009, 05:58 PM
Buffman's Avatar
probably best to rid yourself of whatever that TPS enhancer does.
Burnout!
Exhaust Video
Misc Video New
^^ Gone 7/12/09, but not forgotten
Buffman is offline
post #8 of (permalink) Old 07-29-2009, 06:01 PM
daveq's Avatar
whats a good one to get
daveq is offline
post #9 of (permalink) Old 07-29-2009, 06:03 PM
daveq's Avatar
and where from
daveq is offline
Nitrous, Yes or No? ImpSS07 Chevy Impala 8th Gen Discussion 3 02-17-2009 07:26 AM
what to replace before instaling nitrous kit 2000 z28 camaro with lt1 an headers dereck Automotive Discussion 1 08-12-2008 07:00 AM
