my 2003 impala had to have the gaskets replaced on the manafold, after picked... - Chevy Impala Forums
N2O, Methanol, Water, and Alcohol Injection N2O, Methanol, Water and Alcohol injection.
post #1 of (permalink) Old 01-30-2008, 01:38 PM
imapla
imapla's Avatar
Quoted: Post(s)
...up, it has no power what is wron first of all, i lost power, it would fall flat on its face when I drove. I took it to the garage and was told that the radiator fluid had went into the mainafold and that the gaskets would have to be replaced. While getting this replaced the thermostate was also replaced. I got car back and I still dont have power. It is hard to get the car above 40 miles an hour. Okay I will be starting out to drive i can get to about 20 mph and then I loose power. I let the peddal up and push back down and i have a little power then again all of a sudden I loose power again. I was told by freiends it could be the timing belt or the fuel filter please help
post #2 of (permalink) Old 01-30-2008, 07:27 PM
77Impala's Avatar
Quoted: 6 Post(s)
Take it back to the shop that did the work, they missed some thing. Have them run a scanner check on the computer for codes. Could be an O2 sensor, plugged catilitic converter, or timing is off.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #3 of (permalink) Old 04-27-2008, 08:44 AM
Moose's Avatar
3.4 Litre?
All the GM v6's that would have been available in your car did not have a timing belt, they would have a timing chain. Also, the timing is not adustable, so that would rule that out.
As an aside - those motors use two different length pushrods, and if you aren't careful, you can put them in the wrong homes, and cause all sorts of unique concerns.
94 BBB Clone - when it grows up, it's going to be a racecar.
08 F-350 Super Duty 4x4 6.4 Diesel (26MPG)
Ford Diesel Certified Technician
Moose is offline
post #4 of (permalink) Old 04-25-2010, 01:38 PM
Elbereth's Avatar
Unhappy I have the exact same problem.
I am right in this guy's boat, and I'm missing my paddles.
I've never had a problem with my car, and I absolutely love it. But, just recently on a very long trip, I lost all power. I replaced the LIM gaskets, and after doing that, I'm completely without power. Acceleration is sluggish, with occasional surges and sputters, there's a loud 'exhausty' sound coming from the engine compartment when I hit the gas, and I have to struggle with it to get it up to speed. I have another long trip to make soon, and I am worried the car won't make it (2000 miles).
I've had codes read, and they've indicated low thermostat reading (there's gunk in the coolant, and I'm going to do a backflush), and a bad reading on the EGR circuit. That code cleared itself. I've done a suck test on the FPR, and that was fine. Exhaust is coming out of the pipe smoothly, for the most part. No big hiccups, at least. She idles great, and you can rev her up with no problems when she's just sitting there. Put her in gear, and try to drive away, and there's just nothing there. I'm out of ideas, and out of money, too. I could *really* use some DIY tips, if you guys have anything you can think of.
Thanks!
Elbereth is offline
post #5 of (permalink) Old 06-01-2010, 04:27 PM
straitchev's Avatar
Sounds like a clogged catalytic converter. I had the same symptons and error codes on the EGR and mass air flow sensor. Replaced both and still had the same problem. Brought it to the garage, they changed the cat converter and it brand new again
straitchev is offline
post #6 of (permalink) Old 09-17-2011, 04:00 PM
Impalaforums.com
Stephen's Avatar
my 03 impala lost power all of a sudden one day when i took off from a stop sign. slowly got worse after awhile. my engine would rev up but just wouldnt go fast or anywhere above slow. got hot quicker than it should. bad egr code. it was my converter all along. i cut it off with a sawzaw and welded a new one on. got 90 bucks for my old one too and the new one only cost 80!
Stephen is offline
post #7 of (permalink) Old 01-10-2013, 12:36 AM
g25racer's Avatar
After about 80-100k cat's are DONE.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #8 of (permalink) Old 01-12-2013, 03:20 PM
cptnmrgn667's Avatar
in the interest of this thread and my own lol could u recommend us a good cat?
2003 Impala 3.8
<SOLD>
RICE = Race Inspired Cosmetic Enhancements
cptnmrgn667 is offline
post #9 of (permalink) Old 01-12-2013, 09:29 PM
g25racer's Avatar
^^ I do not have alot of personal experience with replacing cats. I am personally going to be replacing the whole downpipe with a stainless steel.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
LinkBack to this Thread: http://www.impalaforums.com/n2o-methanol-water-and-alcohol-injection/1603-my-2003-impala-had-to-have-the-gaskets-replaced-on-the-manafold-after-picked.html
Impala Forum | 2011 Chevy Impala SS Forums This thread Refback 05-19-2010 02:05 AM
Changing Lower Intake Manifold Gaskets 77Impala 7th Gen Engine Performance 9 10-17-2012 11:37 AM
do i need head gaskets on my 77 impala how important are they? i gets money Chevy Impala Discussion 5 09-22-2008 04:39 PM
my lt1 engine wont start after installing new head gaskets.? diablo x Automotive Discussion 0 09-04-2008 09:18 PM
i just had the engine replaced on my 2003 impala, now it takes 4ever for me... mac_usmc_2k4 Chevy Impala Discussion 1 05-26-2008 11:17 PM
Just picked up a 2008 Chevy Impala with out the Bose sound system? chevyray8 Chevy Impala Discussion 1 03-20-2008 06:15 PM
