I am working on a 2003 impala. heater only works sometimes when the switch is... - Chevy Impala Forums
N2O, Methanol, Water, and Alcohol Injection N2O, Methanol, Water and Alcohol injection.
post #1 of (permalink) Old 01-09-2008, 01:38 PM
300shortmag
300shortmag's Avatar
Quoted: Post(s)
...played with. No vaccume leaks? The fan blows, but it just blows cold air. I have checked vaccume lines, and they are all on tight. I don't here or feel any leaks. I'm not sure what they do when it is not working. As soon as I start fiddling with the hot cold switch and the vaccume lines, it starts working. I worked on another one that was doing somthing similar, and It got sent to our other shop and had a body control module put on it. I work for a school district, and only one of our shops has a computer to program the module. Our head mechanic did the the work, but he has quit. Does it sound like it could be the same thing, or somthing differernt.
post #2 of (permalink) Old 01-09-2008, 01:39 PM
campmano
campmano's Avatar
Quoted: Post(s)
sounds like a temp door actuator, my 88 chrys. heater would work great until it was really cold outside. when i turned the heat temp down it would work fine. but it would not get hotter when i turned it back up. only cold air.
bad smell from vents and fan switch stopped working chnike Chevy Impala Discussion 5 05-29-2013 11:51 AM
in my 2004 impala ls my heater stopped working on my drivers side,i have dual Chris K Chevy Impala Discussion 4 09-30-2008 06:43 PM
Heater/ac fan on my 2005 Impala only works at about half speed when on high. Jamy K Chevy Impala Discussion 1 06-11-2008 04:10 PM
2004 chevy impala overheating, leaking coolant,heater not working need help? Greg B Chevy Impala Discussion 2 04-27-2008 09:35 AM
