What I did on vacation - Chevy Impala Forums
Go Back   Chevy Impala Forums > General Discussion > Media Bucket
Media Bucket Found some cool automotive-related pictures on the net? Want to share videos of your ride? Post Chevy Impala or other car-related pics and videos here!
Old 07-22-2012, 10:28 AM   #1 (permalink)
VTSS's Avatar
Hey everyone, I havent been on here in a while but I have doing a lot of work on the impala. Recently hit 100k miles, bought it at 52k. I figured it was time for a tune up. Some of you may have seen these on NAIOA. Here are the pics
It took myself and my best friend 6 hours to remove and a total of 15 hours to take out, replace parts and put back in. It is running great. Here is my personal maintenance record since I bought the car
60,000 miles: Lower intake manifold gasket, orange to green coolant swap, valve cover gaskets, thermostat, K&N intake
72,000 miles: Accessory belt tensioner pulley replaced
80,000 miles: New brake rotors & pads
92,000 miles: Dynomax catback exhaust system
98,000 miles: Window tint, new heat blend door actuator, new cabin air filter, new speakers, remote start installed
98,500 miles: New accessory & supercharger belts, new accessory belt
tensioner, new coolant elbows, transmission fluid & filter change, new transmission pan gasket, new transmission solenoids, new transmission side door, new transmission side door gasket, new spark plugs & wires, new upper radiator hose, power log, manifold gasket, new upper downpipe gasket, magnetic drain bolt, new exhaust crossover pipe & bolts, PCV valve, new fuel filter
99,000 miles: New supercharger oil
100,400 miles: Goodyear Eagle GT Tires
100,600 miles: Replaced outer tie rod ends
101,000 miles: Dealer 4-wheel alignment
103,000 miles: Engine pulled, new water pump, new 180* thermostat, new valve cover gaskets, new oil pan gasket
103,800 miles: New sway bar end links
VTSS is offline   Reply With Quote
Old 07-22-2012, 11:43 AM   #2 (permalink)
Jd1
The F*** Killer
Jd1's Avatar
Nice! Every time I see this black SS 7th gens makes me sale my 8th gen for one.
Purchased:
1/3/12
09 Impala LT
Installed:
Alarm/Starter, 35% Tints, Black BowTie, Debadge, Trunk Lip, Window Visors, 18X8.5 Gunmetal/Polished ADR Battle EXE 245/45/18, 15MM Rear Spacers, Ebay Lowering Springs 1.7In, Monroe Struts & Mounts, Shorted Dog Bone, H.I.D 55W Ballast W/ 35W 5K Bulbs, Retrofit Black Headlights.
Future Mods:
Black Roof
~Jose
Jd1 is offline   Reply With Quote
Old 07-23-2012, 07:14 PM   #3 (permalink)
VTSS's Avatar
Thanks. Yeah I do love the styling on the 04-05 SS, just something about it. I only wish they were RWD and available in standard.
Old 07-24-2012, 05:03 AM   #4 (permalink)
Forum Foto Fanatic
tonyc712000's Avatar
HMMMmm....can I slip my 3.4 on that stand, and make off wid that 3.8...?
2000 Impala 3.4
LS options
Mods: K&N Drop-in filter
Future mods: CAI, and Cat-back.
Future add-ons: Chevy centers, trim rings,
Window tint
tonyc712000 is offline   Reply With Quote
Old 07-24-2012, 07:16 AM   #5 (permalink)
VTSS's Avatar
Haha. I had a hell of a time getting it on the stand. I got the bolts from Milzy Motorsports but I think the actual "arms" on the stand are too deep. Only 3/4 bolts were long enough to screw into the block, even then they didn't thread in very far so I partly supported it with the engine hoist for backup.
Old 07-24-2012, 09:21 AM   #6 (permalink)
Forum Foto Fanatic
Sounds like a PIA! Hows it going with the build?
2000 Impala 3.4
LS options
Window tint
Old 07-26-2012, 02:38 PM   #7 (permalink)
VTSS's Avatar
I just changed a few gaskets and the water pump, no big build yet. I plan on getting a used engine in the future and re building it with performance parts. But when comes HP also comes a need for a built transmission.
Old 07-26-2012, 07:09 PM   #8 (permalink)
Storm Trooper Ralf
MixedImpala04's Avatar
Ie the motor still out of the car??
MixedImpala04 is online now   Reply With Quote
Old 07-26-2012, 08:33 PM   #9 (permalink)
VTSS's Avatar
Nope I had it out for about 4 hours. 15 hours to remove, replace parts and put back in.
Old 07-26-2012, 08:46 PM   #10 (permalink)
Storm Trooper Ralf
Damn, should have shipped it out to be rebuilt by ZZp or something, or even the tranny to het built up.
Old 07-27-2012, 04:23 AM   #11 (permalink)
Forum Foto Fanatic
Ahhh, I SEEEE.... Well, thanks for the pics! Can't WAIT to see THIS build! I'd LOVE that engine for MY car.......
2000 Impala 3.4
LS options
Window tint
Old 07-27-2012, 02:39 PM   #12 (permalink)
Resident Post-Whore
Nice work, bud. Do mine next? haha
www.basilonestopshop.com
donmateo is online now   Reply With Quote
Old 07-28-2012, 06:21 AM   #13 (permalink)
retiredpauly's Avatar
Did you pull a rod or main cap and have a look at the crank just to see wasssup and how things are going etc.
Timing chain was good ?
A good project done in a weekend !
Cool
Did not know that the 3.8 had a windage tray in it.
I wonder if it's in all 3.8's or just in the supercharged ones ?
retiredpauly is offline   Reply With Quote
Old 07-29-2012, 08:56 AM   #14 (permalink)
outonthetiles's Avatar
They all do. Its part of the oil pan gasket. When they switched to an aluminum oil pan on the series III motors in '05ish, the windage tray was built into the oil pan. Impalas never got the aluminum pan, though.
5 Speed '00 Impala
outonthetiles is offline   Reply With Quote
Old 08-02-2012, 07:33 AM   #15 (permalink)
VTSS's Avatar
Sure! I had a blast. Does yours have the failing oil pan gasket too?
Cool
I didnt go into it that far. I plan on replacing the cam when I pay the car off and checking all that stuff at the same time.
I never got any emails saying I had more responses, sorry for the late reply everyone!
LinkBack to this Thread: http://www.impalaforums.com/media-bucket/328158-what-i-did-on-vacation.html
Chevy Impala Forums This thread Refback 07-26-2012 08:16 PM
