Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Mechanical and Electrical Problems
Old 09-06-2007, 02:58 AM   #1 (permalink)
preciousmoments
preciousmoments's Avatar
2002 Chevy Impala Service Traction System Light comes on with ABS light;...
...What's the problem? My Service Traction System light comes on sometimes and I hear what sounds like the car adjusting something. It does not come on all of the time but the ABS light is on all of the time. I had the brakes serviced about a month ago so I have new brakes. What is causing this and how much should I estimate the cost to repair the problem?
Sponsored links
Old 09-06-2007, 03:00 AM   #2 (permalink)
Grub
Grub's Avatar
Could be the ABS computer - I had the same problem on our Audi and fixed it for $250 by going to http://www.ModuleMaster.com
Old 09-06-2007, 03:01 AM   #3 (permalink)
dodge man
dodge man's Avatar
i own a repair shop,and its not as bad as it sounds on this one,it could just be maintenance reminder on it causing this to happen they will do this ever so many miles,but i would have it checked,because when they was doing the brakes on it they might have hit a sensor and knocked a wire loose on it or something,but its not a big major thing with it,but take it back and have it checked,at this time there would be no way as to guess the cost of fixing it,if its a loose wire,probably 0 cost on it,but have it checked to be sure,good luck i hope this helps.
vB code is On
Traction Control light bigcat24 Chevy Impala Discussion 11 03-09-2009 11:35 AM
Service Traction Control System indyimpalass 7th Gen Drivetrain 9 02-15-2009 08:09 AM
Service Traction System **Update** indyimpalass Autocare and Maintenance 2 01-23-2009 06:26 PM
Traction control service light cfjames11 Autocare and Maintenance 3 12-07-2008 01:38 PM
Help with my 2002 Chevy Impala with engine light ? TAG Chevy Impala Discussion 1 09-13-2008 06:48 PM
Sitemap Index - Archive
