My 2004 Chevy Impala is having gauge problems. The gas gauge is off, the... - Chevy Impala Forums
post #1 of (permalink) Old 09-06-2007, 01:04 AM
astrokien
astrokien's Avatar
Quoted: Post(s)
...speedomoter is off and so is RPMs??? It doesn't happen all the time, but it started about a year ago. I noticed while driving that it said I was doing 70 when I know it was more like 45. It reset itself and was fine for another 6 months. Same thing happened again. Turned the car off and reset. Now, the gas gauge is acting up. Just did a fill up and the next day it said 3/4. Turned the car off and on and it reset to full where it should be. Today it's happening again. At a stop light, the speedometer says I'm doing 20mph. The RPM looked high and the gas gauge is off again. How can I fix this?? Is it easy (hopefully)???
post #2 of (permalink) Old 09-06-2007, 01:05 AM
K R
K R's Avatar
Quoted: Post(s)
Bad ground cable/wire to the dash.
post #3 of (permalink) Old 09-06-2007, 01:10 AM
Jeff P
Jeff P's Avatar
Quoted: Post(s)
I doubt it's easy. You should probably go to a shop and get ti checked. Of course it may just be faulty wiring
post #4 of (permalink) Old 09-06-2007, 01:10 AM
Brandon M
Brandon M's Avatar
Quoted: Post(s)
Cars are so chock full of electronics, NOTHING'S easy about them. The only thing you could do, within reason, is take it to the nearest GM dealer and have them test it.
post #5 of (permalink) Old 09-06-2007, 01:10 AM
rtkskater44
rtkskater44's Avatar
Quoted: Post(s)
haha i would have to say tht it is deffeintly a computer problem.....their ONLY about 2400 or sumthing like tht .....very expensive for tht stuff.
my jeeps gas gauge is off sumtimes. but only when im down a half tank. but it goes up and down. but i would deff say its the computer. take it to a shop give a recommnedation to see if it is the computer and if it isnt ask them for other suggestions on wat it is
post #6 of (permalink) Old 09-15-2008, 06:59 PM
TheOne's Avatar
Try this.
When your speedo or other instruments are not working.
1) Stop and shut car off
2) With the vehicle off, put it into R (reverse)
3) Attempt to start car a few times (the car wont start in reverse)
This should resync your gauges.
TheOne is offline
post #7 of (permalink) Old 09-15-2008, 07:06 PM
capricewiz's Avatar
Instrument cluster, I've had this problem on a lot of cars. I see them a lot at the dealer.
capricewiz is offline
post #8 of (permalink) Old 09-30-2008, 06:53 AM
ENORMIS's Avatar
Yes i agree bad instrument cluster. New cluster must be programmed by a dealer...
ENORMIS is offline
Chevy Impala Temperature gauge problems? Matt Mechanical and Electrical Problems 2 11-04-2010 01:53 PM
2001 Impala 3.4L Temp. Gauge Problems samuelcb409 Mechanical and Electrical Problems 2 01-14-2009 04:56 PM
2004 IMpala INstrument gauge problems.? whelchel77 Mechanical and Electrical Problems 1 09-29-2007 07:06 AM
gas gauge problems help? wingit Automotive Discussion 3 09-14-2007 03:23 AM
Overheating problems with my 1969 Chevy Impala SBC 350. Temp gauge reading too hot Just Me Mechanical and Electrical Problems 0 09-06-2007 12:41 AM
