Engine power reduced/ traction control - Chevy Impala Forums
post #1 of (permalink) Old 04-06-2013, 04:21 PM Thread Starter
Drew65's Avatar
Hey guys,
It seems this is a common problem.I have a 2007 Impala LT with about 107,000 miles. (All highway driving). Out of no where, while driving, the display says "Engine Power Reduced" and then switches to "Service Traction Control". Then just like everyone has stated, I have limited power, the check engine light comes on and so does the traction control light. I can drive the car to where I am going, but no acceleration. I shut the car off and a few hours later after I start it again, only the check engine light is still on, but no more messages and the car runs fine. About a day or two later when I start the car even the check engine light is off. No problems or messages, car runs fine. About a week of driving goes by and the whole thing happens all over again at some random time, then clears itself again.
Any advice to what the problem/fix would be? Also, if I go to the dealer and the lights are off with no messages, can they diagnose the problem? Is there a memory in the computer for past codes or does it have to be actually happening? Thanks for any help/advice.
I really prefer a big block with no computer and a carburetor!
Drew65 is offline
post #2 of (permalink) Old 04-06-2013, 11:57 PM
g25racer's Avatar
I am not all that familiar with these cars but, to me it sounds like you have a faulty ABS harness, sensor, or possibly moisture in the abs connection.
Yes the codes are stored and the dealer should be able to view them.
Personally: I would take all the wheels off and inspect the abs harness's to each wheel. Check for binding or cracked wires. Then, remove the connector going to each hub and use compressed air and a small brush to clean the contacts. Then, apply a few dots of dielectric grease (bought at any auto store) to each terminal. This will keep moisture out.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #3 of (permalink) Old 04-08-2013, 12:56 PM
Definitely get that code read, if it turns up a p2135 I think it was, you need to replace the throttle body. Of course check the code first though and post it here.
post #4 of (permalink) Old 04-09-2013, 02:13 AM
g25racer's Avatar
^^ Wow a throttle body issue on these 8th gens will cause the "Service Trac control" to appear? I did not know
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #5 of (permalink) Old 04-09-2013, 10:16 AM
Thats more secondary to the "reduced engine power" issue, it shuts down everything and goes into fail safe mode. I'm not saying necessarily that is what is going on here, just a possibility.
post #6 of (permalink) Old 04-09-2013, 10:34 PM
g25racer's Avatar
^^ Gotcha
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #7 of (permalink) Old 04-10-2013, 04:11 PM Thread Starter
Drew65's Avatar
Thanks for the advice. I am a little confused though. Why would the message about the "Traction Control" come up if it is related to the throttle body? I may replace the throttle body anyway (most guys here say it's cheap enough and very easy to replace). I would think that ANY problem would trip the "reduce engine power". Like you said, it is the failsafe default for any of the vehicles failures/conflicts. But that would be the secondary step AFTER the computer detects a primary problem. In this case the traction control.
Not sure if that makes any sense but that's the way I would think-- but maybe not the computer on these cars!! Thanks again for your input!!
Drew65 is offline
post #8 of (permalink) Old 04-11-2013, 04:16 PM
I'm thinking traction control gets disabled BECAUSE of the reduced engine power/limp mode. You can replace the throttle body if you want, it is extremely easy, but its close to $300, which to me is far from cheap. I would get that code read first.
post #9 of (permalink) Old 04-17-2013, 08:41 AM Thread Starter
Drew65's Avatar
I just had the car scanned and the display says "Throttle Position Sensor" is the problem. Going to order one and put it in to see if that fixes it.
Drew65 is offline
post #10 of (permalink) Old 04-17-2013, 12:39 PM
Throttle body, the TPS is integrated, can't be purchased separately. Fortunately, it doesn't need to be programmed on these cars, it's plug and play.
post #11 of (permalink) Old 04-28-2013, 11:36 AM Thread Starter
Drew65's Avatar
Well, you can buy the "throttle position sensor" separately. I ordered one online for $60 and installed it in about 15 minutes. It's very easy to do. It mounts on the side of the throttle body with 6 clips. If you do order the entire throttle body (for $135), the throttle position sensor is included. I did the install and everything seemed OK for about two days, then all the warnings and reduced power again!!! So this time I went to another shop, they scanned it and told me '"throttle position sensor" again. BUT, then the guy laughed and said "yeah, we used to call that a gas pedal". Holy cow! Just like on my other car the "fly by wire" gas pedal (sensor) went bad. So I ordered the accelerator pedal assembly on line for $65. Installed that in about 5 minutes (two bolts and plug it in). So far, all is well after a week. Just one last question: The check engine light is still on. Thought it would go off after some good input into the computer while driving. Does it need to be reset? or how long will it take to reset itself? Thanks!
PS While I had the TPS off the throttle body I took a look at the white plastic gear that so many people say goes bad or gets stripped. It looked OK.
Drew65 is offline
post #12 of (permalink) Old 04-29-2013, 01:22 PM
My gears looked fine too, but replacing it still fixed it. The code for the pedal should be different than the code for the tps, should say sensor input or something like that. Where did you get the parts? When I purchased only the dealer had anything, and it was only the entire TB you could get.
post #13 of (permalink) Old 05-12-2013, 10:58 AM Thread Starter
Drew65's Avatar
Been driving awhile to see what would happen... I get my parts from Rock Auto. They always have a good selection and their prices are usually 20% less than the auto stores. They had all the parts sold separately. --- So the "check engine" light is still on, but the car runs fine and no error messages. I went and had it scanned again. Now it says "Canister Vent Valve Solenoid". The code is P0449. I can get that too for about $45. It is an easy access/install part next to the gas tank under the car. I probably will do it. They said it could also be a bad Vapor Canister or Canister Purge Valve. Where are these located??? Thanks!
Drew65 is offline
post #14 of (permalink) Old 05-13-2013, 03:58 PM
You should be able to clean and lube the canister vent, that usually gets them working again. The purge valve is located on top of the engine.
post #15 of (permalink) Old 05-20-2013, 06:01 PM
saxmonster's Avatar
Hey Guys where do you go to have the codes read? I have a little pocket one that shows no codes on my 03 impala but I am have issues with the traction control coming on when i first pull out of the driveway and now today my dash lit up like a firework show with abs, traction control off and service traction control on the display. Turn car off to do errands and it all went away but now I notice my abs coming on sometimes when i go to stop. That could be a little dangerous if or when i may need to slam on them and it doesn't allow me to brake hard. Does the dealer cost to read codes?
saxmonster is offline
LinkBack to this Thread: http://www.impalaforums.com/mechanical-and-electrical-problems/341454-engine-power-reduced-traction-control.html
Engine Power Reduced Traction Control Chevy Impala Forums - Cariinfo.pe.hu This thread Refback 01-08-2015 06:24 AM
08 impala code p2138 This thread Refback 12-08-2014 12:01 PM
09 Impala engine/traction control light slbrewer Mechanical and Electrical Problems 41 06-06-2015 09:31 AM
Reduced Engine Power and Service Stability Control msg/Throttle Body issue Bminder 8th Gen Engine Performance 25 04-23-2014 09:08 AM
2011 p2138 reduced engine power billcost Mechanical and Electrical Problems 29 04-09-2014 07:31 AM
Engine power has been reduced warning??? waitemike85 Chevy Impala 8th Gen Discussion 4 04-13-2012 10:37 AM
Chevrolet : Impala LS Great on Gas, V6, Power Seats, Traction Control, ABS RSS Bot eBay Cars For Sale: Impala 0 10-29-2010 11:10 AM
