2002 keyless remote issues - Chevy Impala Forums
post #1 of (permalink) Old 01-28-2013, 07:45 PM Thread Starter
Hazardous Materials
02chevyimp's Avatar
ok here goes
i have a 2002 LS that sat for a year and a half to two years the battery did go dead. the car was given to me with one key and one remote. the remote is transmitting i have tested it, but for piece of mind i purchased two brand new remotes from a dealer.
i try to program them and go in to the settings on the radio, there is NO fob program feature in the radio.
what direction do i need to go as far as programming these.
i have an autel scanner that has the features for fob programming, but its like the car doesnt have the rke feature.
thanks in advance for any guidance
02chevyimp is offline
post #2 of (permalink) Old 01-31-2013, 08:41 PM Thread Starter
Hazardous Materials
02chevyimp's Avatar
anyone???
post #3 of (permalink) Old 02-01-2013, 10:54 PM
Bart77's Avatar
Quoted: 15 Post(s)
Here are a couple of ways to programs Fobs in your 2002 impala.
This method may work if you do not have a Tech2
    • 1 Enter your vehicle on the drivers' side and insert your key into the ignition switch. Switch your key to the "On" position, but refrain from cranking the engine.
    • 2 Push in the "DISP" button on your car radio and hold it for five seconds until you see the settings menu.
    • 3 Hit the "Up" or "Down" arrow buttons on the radio until you find the "FOB PROG" option. Push the "DISP" button again and you will see the "PUSH FOB" command appear on-screen. Immediately push the "Lock" and "Unlock" buttons simultaneously and hold for 15 seconds or until you hear the car chime. Continue repeating steps 2 and 3 for any other programmable options on your vehicle.
    • 4 Exit the programming mode by pushing the "Up" or "Down" arrows key on the radio until you find the "Exit" command. Hit the "DISP" on the radio to leave the programming mode. You will hear a chime verifying exit.
Use this one if you have access to a Tech2
Remote Control Door Lock Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
1. Install a scan tool.
2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
3. Press the START soft key on the scan tool.
Important: The scan tool must stay connected until all of the transmitters are programmed.
4. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 510 seconds, the scan tool will indicate that the transmitter is programmed.
5. Repeat the previous step in order to program up to 4 transmitters.
6. Remove the scan tool.
7. Operate the transmitter functions in order to verify correct system operation.
Bart77 is offline
post #4 of (permalink) Old 02-02-2013, 04:32 PM Thread Starter
Hazardous Materials
02chevyimp's Avatar
bart77 thanks for the reply... i have tried the program through the radio the problem is it doesnt show the program fob feature
it seems i cant access anything through the scan too either..
could this be because the car sat for 2 years with a dead battery??
post #5 of (permalink) Old 02-03-2013, 09:27 AM
Bart77's Avatar
Quoted: 15 Post(s)
If the "fog prog" option does not show up on the radio setup and the scan tool is unable to program the remote it may be possible that your vehicle didn't come with RKE or the option for RKE was lost in the BCM and it needs to be turned on again. Sitting with the battery dead for 2 years shouldn't have had anything to do with it, but maybe it may have led some modules to loose their settings memory?
Bart77 is offline
The Following User Says Thank You to Bart77 For This Useful Post:
02chevyimp (02-03-2013)
post #6 of (permalink) Old 02-03-2013, 06:46 PM Thread Starter
Hazardous Materials
02chevyimp's Avatar
the car is an LS with every option..the fobs were purchased from a gm dealer by VIN
i bought the car from by brother in law and it came with a fob and i remember him using the remote on the car when he drove it
i might need to get a tech 2 instead of my gst
Keyless Entry Remote charmer37 Audio, Video, and Electronics 7 01-28-2013 09:09 PM
can you replace keyless remote with alarm remote? Hersbird Chevy Impala 8th Gen Discussion 4 07-16-2012 10:31 AM
Unlocking the car without keyless remote tmusquiez Automotive Discussion 7 08-14-2011 01:27 PM
keyless remote mml Audio, Video, and Electronics 14 04-01-2011 01:30 PM
How to disable keyless remote on 2002 chevy impala??Urgent help plz. kbsquared Chevy Impala 7th Gen Discussion 4 06-18-2010 05:46 PM
