06 Engine Hot Message - Chevy Impala Forums
post #1 of (permalink) Old 05-16-2012, 11:16 AM Thread Starter
jw06's Avatar
I have an 06 Impala with the 3.9. We are getting a "Engine Hot AC OFF" message but the temperature gauge doesn't move off "C". Coolant if full. Could this be the thermostat or the temperature sensor?
jw06 is offline
post #2 of (permalink) Old 05-16-2012, 11:41 AM
Possibly both, but definitely temp sensor.
post #3 of (permalink) Old 05-16-2012, 12:00 PM Thread Starter
jw06's Avatar
If it's just the sensor would it be OK to drive?
jw06 is offline
post #4 of (permalink) Old 05-16-2012, 01:09 PM
systemcheck2006's Avatar
does temp gauge move after starting car in morning, i had same message, pay attention to it it. i replaced sensor and did nothing. then noticed that when temp got to certain degree (same spot everyday) the temperature would drop to c, replaced thermostat and the inner gasket rubber thingy was all gnawled up.
then you'd be normal."
systemcheck2006 is offline
post #5 of (permalink) Old 05-16-2012, 04:31 PM
I would go ahead and replace both, they are cheap parts. As for it being safe to drive... as long as it isn't actually overheating, I wouldn't worry about it too much, but definitely keep an eye on it.
post #6 of (permalink) Old 05-16-2012, 09:23 PM
rangel515's Avatar
What brand of thermostat did you use?
Also which rubber "thingy" did you change?
Do you rembered any part #s
rangel515 is offline
post #7 of (permalink) Old 05-16-2012, 10:29 PM
It's Only A V6
adamg38671's Avatar
same thing happened in my 09.. replaced thermostat and worked fine.. the rubber in the thermostat was holding it open
2009 Impala LT
Vent Visors
K&N Air Filter
20% Tint All Around
Plasti Dip OEM Rims
Plasti Dip Bowties
Debadged
Carbon Fiber Pillars
Black Pin Stripe
HID Kit
Black Tail Lights
Engine Bay Paintings
More soon to come!
adamg38671 is offline
post #8 of (permalink) Old 05-17-2012, 09:08 AM
the rubber thingy is attached to the thermostat
part no. is 48808
Buy Stant Xactstat™ Thermostat, 185 Degrees Fahrenheit 48808 at Advance Auto Parts
it was $20.00
it's quite simple to do
open peacock - drain coolant below thermostat
remove two nuts from thermostat from upper hose
pay attention to how its pulled out, place in same way
and reverse
post #9 of (permalink) Old 05-17-2012, 09:10 AM
It's Only A V6
adamg38671's Avatar
^ correct
2009 Impala LT
Vent Visors
K&N Air Filter
20% Tint All Around
Plasti Dip OEM Rims
Plasti Dip Bowties
Debadged
Black Pin Stripe
HID Kit
Black Tail Lights
More soon to come!
post #10 of (permalink) Old 06-04-2012, 03:53 PM Thread Starter
jw06's Avatar
Just removed the thermostat housing and the rubber gasket was bad.
Do you need to put RTV on the flange or just clean bot surfaces.
Thanks for all the help!
jw06 is offline
post #11 of (permalink) Old 06-04-2012, 05:33 PM
Raider's Avatar
I'm using the fail safe 195 degree from auto-zone for $11.99. The fail safe will stay in the open position if wears out so you will not over heat. I stay away from the 185 degree ones because GM engines do not run properly when they are to cool. Normal operating temp is at 195. Gm also recommends the 195 degree.
The first time I changed mine I used nothing. The problem with using nothing is it is such a pain to get that thing put back together the thermostat will slip just enough so that when you tighten the housing you will pinch the seal. So this second time I put a small bead of RTV black to hold it in place. I then let it sit for a few hours before I tightened 'er down. You can use the red or whatever. I had the black laying around so I used it.
Raider is offline
post #12 of (permalink) Old 06-05-2012, 02:28 PM
It's Only A V6
adamg38671's Avatar
Thanks for the idea raider
2009 Impala LT
Vent Visors
K&N Air Filter
20% Tint All Around
Plasti Dip OEM Rims
Plasti Dip Bowties
Debadged
Black Pin Stripe
HID Kit
Black Tail Lights
More soon to come!
post #13 of (permalink) Old 09-15-2013, 12:04 PM
GregC53's Avatar
My 2008 Impala Lt with 3.5 Lt. Just started doing this last night with my Wife. I haven't driven it today, But I went out & Checked the water & Everything seemed to be alright. I was wondering, In a couple of peoples Post on this issue they said their Temp. Gauge went to "C". What caused that? Just Curious.
Thanks for the Advice I got from this forum, Will probably go & Get me a Thermostat today!
GregC53 is offline
post #14 of (permalink) Old 01-10-2014, 11:35 AM
blackmagic's Avatar
im having this very saem issue in my 08 ltz now. gauge stays on C and gives the ENGINE HOT TURN OFF A/C message. looks like I need to do some work on her then
blackmagic is offline
LinkBack to this Thread: http://www.impalaforums.com/mechanical-and-electrical-problems/323512-06-engine-hot-message.html
06 Engine Hot Message - Chevy Impala Forums This thread Refback 06-30-2016 01:50 PM
2006 3.9L ENGINE HOT A/C OFF Message scusack Chevy Impala 8th Gen Discussion 53 11-12-2014 04:05 PM
Low Coolant in Message Box Achiyan Chevy Impala 7th Gen Discussion 4 06-22-2011 12:19 AM
low oil message bigjohn23 Chevy Impala 8th Gen Discussion 1 03-03-2010 07:35 PM
Change Engine Oil Message luke_fairs Chevy Impala 7th Gen Discussion 9 07-02-2009 06:13 PM
2003 Chevy Impala...Change engine oil message just came on.. is it simple to fix? backyard mechanic Chevy Impala Discussion 2 05-28-2008 06:40 PM
