aftermarket stereo help w/ wiring. - Chevy Impala Forums
post #1 of (permalink) Old 01-24-2011, 10:41 AM Thread Starter
Mnguyen's Avatar
I was going to install a new aftermarket stereo into my 04 impala so i figured id do it myself and pull everything apart and try to install it.
the problem is that i have half of the radio harness and the antenna adapter available but not the small radio harness that my old factory radio used. i tried to connect everything to the aftermarket stereo without the small harness and the thing is that there is no sound and there is no illumination. the aftermarket stereo didnt come with illumination wires so i left that alone with the RCAs.
also when i go to turn my car on the stereo evidently has the function of taking in cds and ejecting them but no sound/radio.
heres some pix as to help out hopefully.
black one was the one i was refering to as 'smaller' one. thanks in advance.
Mnguyen is offline
post #2 of (permalink) Old 01-24-2011, 03:48 PM
cap89's Avatar
the black one is for onstar not needed.dose it have a factory amp
if it dose did hook up amp turn on blue/ white off new radio to blue wire in harness
cap89 is offline
post #3 of (permalink) Old 01-24-2011, 07:51 PM Thread Starter
Mnguyen's Avatar
woahh braah. the pics are hard to make out for me.. but what youre saying is that i should connect the blue/white wire from the car to the blue/white to the harness?
i think i already did..i tested the setup with a multimeter and everything is connected to where it should be.. heres a recent pic.
the manual that came with it said that that particular blue one was the amp wire plus it was the only blue one there.
and heres the harness and the aftermarket harness in whole.
Mnguyen is offline
post #4 of (permalink) Old 01-25-2011, 03:11 AM
cap89's Avatar
the red wire you have connected is not in the car as acc . you can get switched (acc) power at ing switch brown wire fuse with 10 amp fuse
cap89 is offline
post #5 of (permalink) Old 01-25-2011, 03:52 AM Thread Starter
Mnguyen's Avatar
uh..what?
are you saying the red wires i connected are not meant for each other? thats the problem?
and to connect the red wire from the aftermarket stereo with a brown wire?
Mnguyen is offline
post #6 of (permalink) Old 01-25-2011, 06:33 AM
cap89's Avatar
uh..what?
yes that is one of the things the module dose in my pic(blue box) gives you switch power .factory radio turns on by data from bcm . the ignition switch is one of the easy places to get switch power (brown wire),or buy the right harness that gives you acc power
cap89 is offline
How do you replace 2004 Chevy Impala factory stereo with a aftermarket stereo? Stephen B Audio, Video, and Electronics 16 05-28-2011 08:35 AM
'07 SS aftermarket stereo install help stevecon1 Audio, Video, and Electronics 5 07-22-2010 07:23 AM
Installing aftermarket Stereo bigfish12 Chevy Impala 8th Gen Discussion 5 03-12-2010 01:25 PM
Stereo Wiring aaronkohn Impala 1st - 5th Gen Discussion 4 02-14-2010 06:09 AM
Aftermarket Stereo Installation Help! stevenshepard05 Audio, Video, and Electronics 1 09-25-2009 06:43 AM
