Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Mechanical and Electrical Problems
Old 02-09-2010, 08:22 AM   #1 (permalink)
Borderguy190's Avatar
Cooling system issues
Remove this ad!
I am pretty mechanically disinclined, which I hate. I ended up here because my wife's Impala was overheating and losing coolant with no visible coolant leaks. I made an attempt at replacing the thermostat, but screwed up the air intake gasket thingy. The shop replaced that, but now the temp gauge will yo-yo. When the temp climbs the heater stops blowing hot air until the gauge drops into the normal range. Sometimes it just yo-yos, sometimes it pegs to hot.
In trying to solve this online without more money to the mechanic I 'discovered' the bleeder valves. I am not sure if this has helped yet because of the snow falling right now. I have no desire to drive more in this white crap...
BUT- I broke the bleeder valve above the, I believe, water pump on the passenger side front of the engine. Is there anyplace online to order that little assembly? My google-fu is weak so far.
Thansk for listening, and any suggestions.
Harry
Borderguy190 is offline
Old 02-09-2010, 12:48 PM   #2 (permalink)
wanderson75's Avatar
What year, trim level, and engine displacement Impala do you have?
–adjective
wanderson75 is offline
Old 02-09-2010, 04:05 PM   #3 (permalink)
2000, 3.4 engine, on the trim level, I am not sure. I believe it is the basic model, I bought used so I am not positive.
Old 02-10-2010, 09:09 AM   #4 (permalink)
I would try to stick to the local stores just for the convenience, that part isn't likely to be expensive. It sounds like you have air trapped in the system though, so you will want to use the bleeders. Be careful with them however, lefty loosey righty tighty. And tighten them gently, there is no reason to crank them down.
Dual Flowmaster exuast with hi-flow cat (waiting to be installed)
2.41 Open carrier performance!
(95 9C1 3.08 waiting to be installed!)
16x8 American Racing Baja's with 225/60/16 Pirelli P5's
Panasonic CD player with all Polk speakers 2-4x6, 2-6x9, 2-12" on alpine 4 channel (till I get my other amp fixed).
Old 02-10-2010, 09:49 AM   #5 (permalink)
04DetroitLS's Avatar
I was going to say if youre a 3.8 comeon over, but i dont touch 3.4's...ask wanderson, i conned him into a 3.8 swap just so we could work on his car ;)
04DetroitLS is offline
Cooling Fan Issues lexa1051 Chevy Impala 7th Gen Discussion 3 11-02-2009 10:24 AM
3.8 cooling issues. HighwayLurker Chevy Impala 7th Gen Discussion 3 10-02-2009 06:23 AM
2004 Impala 3.4 V6 cooling system question? Matt Chevy Impala Discussion 1 06-19-2008 05:08 PM
03 impala with no A/C or cooling fan? BOB Chevy Impala Discussion 3 06-02-2008 06:04 AM
cooling fans BIGBOY34 Chevy Impala 7th Gen Discussion 2 04-16-2008 11:36 AM
