I have a 2005 chevy impala,the speedometer quit working and the temp gauge? - Chevy Impala Forums
post #1 of (permalink) Old 08-31-2007, 09:57 PM
areyouatoj
areyouatoj's Avatar
Quoted: Post(s)
please help I cant afford a machanic
post #2 of (permalink) Old 08-31-2007, 09:58 PM
giff01
giff01's Avatar
Quoted: Post(s)
Is it not warranty still being an 05?Sounds like the insturment cluster packed it in.If no warranty,used parts is your cheaper option,Good luck
post #3 of (permalink) Old 09-15-2008, 07:49 PM
TheOne's Avatar
Try this.
When your speedo or other instruments are not working.
1) Stop and shut car off
2) With the vehicle off, put it into R (reverse)
3) Attempt to start car a few times (the car wont start in reverse)
This should resync your gauges.
TheOne is offline
The Following User Says Thank You to TheOne For This Useful Post:
Funmavrick (09-09-2013)
post #4 of (permalink) Old 09-15-2008, 08:14 PM
capricewiz's Avatar
you can get your instrument cluster rebuilt by a company called BBengineering. Or they'll send you a rebuilt one and you send your old one back for a core.
capricewiz is offline
post #5 of (permalink) Old 09-16-2008, 05:29 AM
Moderator
04DetroitLS's Avatar
http://www.bbengineer.com/cars/impala/store.htm
04DetroitLS is offline
post #6 of (permalink) Old 08-18-2009, 11:04 PM
chevyp2p's Avatar
Thumbs up Solution For Your Speedometer Problem
This is a common problem with all the GM vehicles from 2000 to 2006 I had the same problem in my 2005 Impala the speedometer went haywire at 89K miles. I found a website where I had it fixed for $120 dollars. here is the website in case you want to check it out.
speedometergaugerepair.com
chevyp2p is offline
post #7 of (permalink) Old 08-19-2009, 08:47 AM
Moderator
you can go used or grab the steeper motors off ebay and replace (if your good w/ electronics)
post #8 of (permalink) Old 02-28-2015, 08:58 AM
jdw1764's Avatar
Quick fix for Speedometer for '05 Impala
Does this really work? I need my car today and to travel a little distance away and do not want to be stuck...Thanks
jdw1764 is offline
post #9 of (permalink) Old 12-17-2015, 04:31 PM
Doris's Avatar
Originally Posted by TheOne View Post
Try this.
You rock! Worked for me! Well, my temperature gage hasn't worked in over a year. Today my speedometer went wacko. It clocked 160 when I was doing about 40km. Drove home, turned it off and the needle stayed there. I started doing research and people were quoting up to $600. for a repair. I am on a disibility pension with no savings, so this was a nightmare. I am presently dealing with trying to get my heat fixed because I have no heat. Came across your post and thought there was nothing to lose. I had to do it about 4X and each time, it edged its way back to zero. Then I took my 2005 Impala for a run and it works perfectly. My temperature gage is still off, but so happy your suggestion worked for me. What a relief. Thank you so much!
Doris is offline
post #10 of (permalink) Old 12-17-2015, 07:26 PM
retiredpauly's Avatar
Quoted: 70 Post(s)
Glad a 7yr old post worked for you.
Welcome to the forum too.
What part.of Canada are you from ?
Tell us more
We're harmless here.
Really
Well "most"of us are.
retiredpauly is offline
LinkBack to this Thread: http://www.impalaforums.com/mechanical-and-electrical-problems/22-i-have-a-2005-chevy-impala-the-speedometer-quit-working-and-the-temp-gauge.html
I Have A 2014 Impala And My Speedometer Is Not Working 2015 | 2015/2016 Scholarships for All 2015 This thread Refback 03-12-2015 03:46 PM
Wedding Photographer Sydney This thread Refback 09-27-2014 05:58 AM
Photography Studio Sydney This thread Refback 09-27-2014 05:58 AM
Family Photography Sydney This thread Refback 09-27-2014 05:58 AM
Wedding Photography Sydney This thread Refback 09-27-2014 05:58 AM
Professional Photography Sydney This thread Refback 09-27-2014 05:57 AM
Wedding Photographer Sydney This thread Refback 09-27-2014 05:57 AM
Family Photography Sydney This thread Refback 09-27-2014 05:57 AM
Wedding Photographer Sydney This thread Refback 09-27-2014 05:56 AM
Professional Photography Sydney This thread Refback 09-27-2014 05:55 AM
Photo Sessions Sydney This thread Refback 09-27-2014 05:55 AM
Professional Photography Sydney This thread Refback 09-27-2014 05:54 AM
Wedding Photographer Sydney This thread Refback 09-27-2014 05:54 AM
Family Photography Sydney This thread Refback 09-27-2014 05:53 AM
Untitled document This thread Refback 09-22-2014 02:27 AM
Untitled document This thread Refback 09-22-2014 02:26 AM
Untitled document This thread Refback 09-22-2014 02:25 AM
Untitled document This thread Refback 09-22-2014 02:24 AM
Untitled document This thread Refback 09-22-2014 02:23 AM
Untitled document This thread Refback 09-22-2014 02:22 AM
Untitled document This thread Refback 09-22-2014 02:21 AM
Untitled document This thread Refback 09-22-2014 02:20 AM
Jak za?o?y? sklep internetowy? This thread Refback 09-07-2014 07:00 PM
Untitled document This thread Refback 09-07-2014 07:00 PM
Jak otworzy? sklep internetowy? This thread Refback 09-07-2014 06:58 PM
Untitled document This thread Refback 09-07-2014 06:58 PM
Za?o?enie sklepu intermetowego krok po kruku This thread Refback 09-07-2014 06:56 PM
Jak za?o?y? sklep internetowy? This thread Refback 09-07-2014 06:54 PM
Jak otworzy? sklep internetowy? This thread Refback 09-07-2014 06:53 PM
Jak otworzy? sklep internetowy? This thread Refback 09-07-2014 06:51 PM
Za?o?enie sklepu intermetowego krok po kruku This thread Refback 09-07-2014 06:51 PM
Co jest potrzebne do prowadzenia sklepu internetowego? This thread Refback 09-07-2014 06:49 PM
Untitled document This thread Refback 09-07-2014 06:49 PM
Jak za?o?y? sklep internetowy? This thread Refback 09-07-2014 06:48 PM
What's the cost to replace a speedometer on a 2005 Chevrolet Impala? This thread Refback 06-15-2011 11:43 PM
2005 Chevy Impala Problems This thread Refback 05-21-2011 06:25 PM
What's the cost to replace a speedometer on a 2005 Chevrolet Impala? This thread Refback 04-19-2011 09:34 AM
how do I fix 2001 chevy impala temp. gauge?? hntraut Chevy Impala Discussion 4 12-16-2008 09:18 AM
I own a 2005 Chevrolet Impala trouble with dash panel gages, (gas,speedometer,temp.)? Javier G Mechanical and Electrical Problems 1 09-15-2008 07:58 PM
1995 chevy impala ss digital speedometer not working? MYSTIKAL_NLP Chevy Impala Discussion 2 05-23-2008 04:38 PM
I have an 05 impala and the temp gauge is pointing down and the speedometer sits... shaleda78 Chevy Impala Discussion 5 04-11-2008 08:26 AM
My 2002 Chevy Impala putters and the temp gauge is constantly moving up and down.? lorene s Mechanical and Electrical Problems 0 08-31-2007 09:45 PM
