Headlights don't work - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Mechanical and Electrical Problems
Old 11-25-2008, 04:57 PM   #1 (permalink)
mommyof2's Avatar
Hi everyone! I just bought a 2001 Impala LS from my grandpa. He was the original owner and I know it's been taken good care of. He parked it when he bought a 2008 Monte Carlo SS. It was parked for about a month(he drove it around the block about once a week for that month to make sure everything was staying in working order) before I got it. He said the headlight thing started 2 weeks into being parked.
Sorry, here's the problem. The highbeams are completely out. I'm sure they didn't both burn out at the same time. Also, the blinker doesn't turn off itself off after a turn. Any ideas on what I could check so I don't go spending a bunch of money chasing the problem down? Thanks!
mommyof2 is offline   Reply With Quote Quick reply to this message
Old 11-26-2008, 02:13 AM   #2 (permalink)
Moderator
04DetroitLS's Avatar
check the bubls first on the headlights, theres 2 white tabs that lift up (easy to remove headlight) once is visible, the other is under the black plastic trim piece, towards the hoods latch ( if you cant find it I'll take pix this weekend)
also check the coonection @ the headlight.
As for the blinker not turning itself off, It prob has to do w/ the switch inside the column ( the click you hear/feel when you turn), this could also be the issue w/ the highbeams as well (if its only the highbeams that dont work) you'll prob need to replace the blinker switch/high beam switch inside the steering column
04DetroitLS is offline   Reply With Quote Quick reply to this message
Old 11-28-2008, 08:58 AM   #3 (permalink)
mommyof2's Avatar
Thanks. Is it hard to replace the switches? My grandpa would be helping me do this and he wanted to ask if we'll have to worry about the airbag deploying or not working properly when replacing it.
Old 11-28-2008, 09:00 AM   #4 (permalink)
COLD STEEL's Avatar
its not exactly easy, typically to get to that switch you usually remove the steering wheel and airbag and tear apart the steering column
COLD STEEL is offline   Reply With Quote Quick reply to this message
Help With Headlights 02SexyImpala Chevy Impala 7th Gen Discussion 11 05-14-2010 07:11 AM
1965 Headlights don't work CBCI65 Mechanical and Electrical Problems 0 11-27-2008 05:53 PM
Headlights 64ImpalaRagtop Restoration Forum 0 11-04-2008 10:30 AM
Why are my headlights dim? waaaaaac Automotive Discussion 2 11-09-2007 06:27 PM
gmc canyon all three lights work on tailight assembly but the tail light dont work.? denny b Automotive Discussion 1 09-07-2007 04:56 AM
