Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Mechanical and Electrical Problems
Old 10-23-2008, 11:15 AM   #1 (permalink)
TuckerN's Avatar
Engine Running Rough
Remove this ad!
OK. So lately my car (1970 impala with a 400ci chevy small block and 2 speed powerglide transmission) has been running a little rough. It idles just fine but when you try to get a little heavy on the accelerator, it like bogs out if that makes any sense. And it doesnt accelerate nearly as fast as it used to. Its fine when you are lightly accelerating but when you try medium to heavy acceleration, it just feels really rough. And if I put it in the low gear and take it a little high into the RPMs, it will backfire. I didnt know if maybe it is a distributer/point rotor problem or carb problem or even something in the block. Anyone got any ideas to this?
TuckerN is offline
Old 10-23-2008, 11:51 AM   #2 (permalink)
Gregg-O's Avatar
How many post's are you going to make about this. When was the last tune-up done? When was the fuel filter last changed.?
Gregg-O is offline
Old 10-23-2008, 12:17 PM   #3 (permalink)
TuckerN's Avatar
sorry. I put it in the other thread but them i saw this one so i thought i would put it here too. I replaced the distributer in april and the plugs and wires were changed about a month and a half ago and the fuel filter was changed about 2 months ago
TuckerN is offline
Old 10-24-2008, 09:19 AM   #4 (permalink)
Gregg-O's Avatar
Could be the accelerator pump in the carb. It gives it the extra shot of fuel when you step on it. Backfire is usually a timing issue. If you have a dwell meter make sure you are at 30 degrees, thats what I always used to run, book calls for 28-32. Make sure the cap is on tight. How old is the coil?
Gregg-O is offline
Old 10-24-2008, 06:34 PM   #5 (permalink)
TuckerN's Avatar
honestly i have no idea. I havent replaced it at all and i have had the car since this last march
TuckerN is offline
2003 Chevy Impala 3.4L Engine Running Hot, Fans Blowing, But No Smoke. jwp1223 Mechanical and Electrical Problems 14 02-02-2009 04:22 PM
my 83 chevy caprice is running really rough need help!? Bryan W Chevy Caprice 2 07-27-2008 05:27 AM
1996 impala runs rough, engine light on, and transmission not shifting... Jeremy K Chevy Impala Discussion 1 05-28-2008 04:20 AM
chevy rides rough in front end? maynerdgcribs Automotive Discussion 1 09-17-2007 02:25 AM
trip mileage resets to 0. Car runs rough with no power.? aznightwolf Automotive Discussion 0 09-11-2007 06:41 PM
