Aftermarket Radio Will Not Turn On. NEED HELP! - Chevy Impala Forums
post #1 of (permalink) Old 10-17-2008, 11:15 PM Thread Starter
Impala_Man's Avatar
Okay, I have a 2003 Impala LS. I got a Pioneer AVH-P5000DVD (which is a flip up dvd player) and when i installed it, it wouldn't turn on. I bought it brand new and i'm positive that it's installed correctly so I don't know why it won't work.
I was thinking that there is some kind of security system on my car that gets activated when the stock radio is removed. But I really don't have a clue why it won't even respond. Does anyone know how to fix this problem?
I would really appreciate it if someone could help me out with this.
Impala_Man is offline
post #2 of (permalink) Old 01-18-2009, 03:43 PM
stevo1390's Avatar
well i installed mine yesterday i got a 2000 impala 3.4. i had the same issue drove me crazy for about an hour til i realized i needed to plug in the door chime speaker or it wouldn't work (i didnt care if the chimes were there). thats how i solved my problem. not sure if that is your case, or whether or not yours needs the door chime speaker and special harness. hopes this helps
stevo1390 is offline
post #3 of (permalink) Old 02-25-2009, 01:48 PM
kiori's Avatar
i HAVE THE SAME PROBLEM PPLS TELL ME ABOUT THE TUNER BOX? DID U HAVE THE TUNER BOX IS NEED TO BE CORRECTLY EQUIPEED TO TURN ON THE RADIO I HAVE THE SAME AVH AND COMES WITHOUT THE TUNER BOX CAN U TELL ME PLS IF U GOT IT TOO AND CAN GIVE ME THE MODEL NO. PLS THXS
kiori is offline
post #4 of (permalink) Old 02-25-2009, 02:06 PM
blusail's Avatar
What harness did you use to connect between the radio and factory harness
blusail is offline
post #5 of (permalink) Old 02-26-2009, 10:22 AM
kiori's Avatar
is the harness black is lookg like the IP BUS but the connector is more big is near up betwwen the ip bus connector and the ipod connect
kiori is offline
post #6 of (permalink) Old 04-02-2009, 11:16 AM
Manoogia86's Avatar
You may have blown a fuse when you installed it... Did you unplug the battery first?
Manoogia86 is offline
post #7 of (permalink) Old 01-30-2010, 11:15 PM
deanhome's Avatar
re:Panasonic AVH-P5000DVD
DO YOU NEED THE TUNER BOX TO POWER THE RADIO I HEARD YOU DID
NOT SURE IF ITS TRUE
HIT ME BACK I GOT ONE 2
deanhome is offline
post #8 of (permalink) Old 02-01-2010, 06:16 AM
wedebrook's Avatar
What tuner box are we talking about?
Rule #2: It's wrong to be French.
wedebrook is offline
post #9 of (permalink) Old 02-08-2010, 05:41 PM
deanhome's Avatar
re:tuner box
it's still not clear if the tuner box is needed i spoke to pioneer recetly and they say no i speak to local shops they say yes
i tend to wanna believe pioneer but we all know what happens when you outsource ya labor it becomes like a box of chocolate
deanhome is offline
post #10 of (permalink) Old 02-09-2010, 06:36 AM
Moderator
wanderson75's Avatar
This is getting convoluted.
Impala_Man
Did you use an adapter harness for the GM Radios? If not, let me know if you have OnStar or not and we'll get you the part number you need.
stevo1390
That's because power is routed through the chime box on the GM harness. If you don't plug in the box, you'll have no power to the radio.
kiori
If you're having issues with your radio, please make another post. Don't hijack someone else's thread.
–adjective
wanderson75 is offline
post #11 of (permalink) Old 02-09-2010, 07:12 AM
wedebrook's Avatar
I don't even know which way is up in this thread anymore.
post #12 of (permalink) Old 02-09-2010, 07:28 AM
Moderator
04DetroitLS's Avatar
this is why i stay out of the audio threads LOL
04DetroitLS is offline
post #13 of (permalink) Old 02-09-2010, 12:16 PM
deanhome's Avatar
just spoke to a tech at pioneer regarding the pioneer avh-p5000dvd
the tuner box is needed to power the avh-p5000dvd or it wont come on
deanhome is offline
post #14 of (permalink) Old 02-09-2010, 01:42 PM
Moderator
The single cable coming from the radio going to the tuner box, I see that. So there are two pertinent questions.
A) is the tuner box plugged in?
B) did you buy the GM adapter harness for the radio to install it?
On a sidenote, any RADIO that has the RADIO TUNER externally is plain retarded.
–adjective
want to install aftermarket tachometer,but don't know where to ............... stattoninc.com Chevy Impala 7th Gen Discussion 3 07-06-2010 07:36 AM
Aftermarket audio for an Impala LS Jurasskick Chevy Impala 7th Gen Discussion 4 12-20-2008 07:19 PM
I am installing a replacement radio in a 2000 Impala. It is a factory radio. When... mark k Chevy Impala Discussion 1 05-18-2008 09:42 PM
Impala SS Aftermarket Parts QuestFor Speed Appearance 2 04-21-2008 12:35 AM
Is it possible to convert an am radio in a 1963 chevy impala to an am/fm radio? Steve F Restoration Forum 2 09-04-2007 05:14 AM
